  2. Captain Dunsel
    KitchenAid dishwasher tech sheet please
  3. Manufacturer: Kitchenaid Type of Appliance: Dishwasher Model Number: kudc10fxss7 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I see manuals for other suffix. Does it work for the seven? Thank you so much!
  4. Today
  5. Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHX68R55UG/63 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual, service mode and troubleshooting guides for model SHX68R55UG/63
  6. Manufacturer: Ge cafe Type of Appliance: Slide in range Model Number: CS975SD2SS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Particularly interested in console and top disassembly instructions thank you
  7. Cville Appliance
    Samsung Cooktop Manual Request- nz30k7570rs/aa
    Thank you very much
  8. Uploading service manual and waiting on approval.
  9. Well deserved @Nathaniel Peterson!
  10. See if you can use this:
  11. Manufacturer: samsung Type of Appliance: Cooktop Model Number: nz30k7570rs/aa Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Couldn’t find manual here and I need to find what f2 means on this cooktop. Thanks
  12. Emperorappliance
    Service manual for Frigidaire FGHB2844LF3
    Y’all are the best! Thanks!
  13. Uses the same tech sheet as this model: May have some similarities to Parts of this manual:
  14. Manufacturer: KitchenAid Type of Appliance: Under the counter ice maker Model Number: KUIX335HPS01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes There’s a tech sheet for a KitchenAid ice maker KUIX505* but it doesn’t match the diagnostic mode in the 335 series. Ice maker makes ice, but it melts quickly. I think water is flowing out over the grid heater onto the ice in the bin. Anyway, a tech sheet for this specific KA ice maker would be awesome, thanks.
  15. Yesterday
  16. Is there any more to that model number? There should be a "/" followed by two digits.
  17. Koi Guy
    Appliantology Live Dojo, Saturday, 7/12/2025 @10 AM ET
    until
    Ya got any of them dojo's?
  18. Son of Samurai
    Banners
  19. Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHE53B75UC Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I need a service manual for this dishwasher, I found a similar model number in the forum but it was for a 2013 model and this is a 2024. The posted manual does not pertain to this dishwasher. Right now I'm getting a water inlet valve icon but the water inlet valve is working I'm suspecting there's a problem with the flow meter but I need the service manual to further diagnose
  20. Manufacturer: LG Type of Appliance: Washer/dryer combo Model Number: WKHC202HBA Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Tes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hi, I'm looking for the service manual and disassembly instructions for this model, if available. Thanks
  21. Manufacturer: LG Type of Appliance: Gas Range Electric Oven Model Number: LSDL6336F/00 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Needing tech manual for LSDL6336F/00
  22. Son of Samurai
    Need service manual WGD5000DW2
    Thanks, Cap!
  23. Whirlpool WGD5000DW2 Dryer Wiring Sheet View File Pub Wiring Sheet - W10185994 - Rev M Submitter Captain Dunsel Submitted 07/07/2025 Category Appliance Repair Manual Pot Luck Supper
  24. Captain Dunsel
    Uses the same tech sheet as this model: This comes up on the Electrolux site: Also this one: Also this one:
  25. Repairman had trouble getting heating element off old GE Potscrubber 940 dishwasher - I believe he had to cut heating element off, connector was different on the replacement one if I remember correct. When he was done, he had to patch a hole in the permatuf bottom, well, it has started to leak. The repairman is going to text me the name of the stuff he used, but I am wondering if there is a better product to use, or suggestions. I assume replacing the permatuf bottom would be tough, unless I could find an old donor machine, and not sure how difficult the job would be. When I removed the bottom panel and watched it run, water was dripping off the plastic cover over the heating element connectors - unto the metal box housing the power connection, so the GFI has been tripping when this area gets wet enough. Circuit breaker has not been tripping. I took some pics, looks like area that needs sealing is simply around where the heating element goes into the permatuf bottom, right now he has some grey stuff applied around the circular opens. I was considering using Sugru moldable glue, which is supposed to be dishwasher safe, good for 356 degrees, or something like that - shockproof - or is there something better for this type of repair?
  26. Manufacturer: Frigidaire Type of Appliance: Refrigerator Model Number: FGHB2844LF3 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Looking for the service manual for this model. I have never seen an ice maker like this before but I have multiple issues with this unit and am looking for an any service manual to assist in this job. Thanks!
  27. Last week
  28. Captain Dunsel
    Electrolux FG EI27BS16JS6 SM Request
    Uses the same wiring diagram as this model: The May have some similarities to Parts of this manual:
  29. Version 1.0.0
    0 downloads
