  2. Jazz Appliance Repair
    Bosch dishwasher SHV78CM3N/23
    You the man! Thank you
  3. Jazz Appliance Repair
    Hisense Freezer HUF210N6AWE service manual/tech sheet
    tHANK YOU!
  4. Manufacturer: GE Type of Appliance: Stovetop Model Number: PEP9036DT1BB Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Need service manual and or tech sheet
  5. Captain Dunsel
    MayTag Dishwasher Schematic Request
  6. Manufacturer: GE Type of Appliance: Washing Machine Model Number: GTW680BMM0DG Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES Thanks!
  7. Manufacturer: MayTag Type of Appliance: Dishwasher Model Number: MDB4949SKZ0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES Thanks
  8. You would think that there wouldn't be a lot going on with an oven's convection fan motor -- and you would be wrong! This Viking convection fan has a number of interesting elements in its circuit that we're going to explore in this post. 1. Is that a 240 VAC power supply for a fan motor? Turns out that you can actually run a fan on 240 VAC if you want to (and if the fan has the proper specs for it). There are even certain benefits to doing so. 2. Not just one, but two capacitors in the motor's circuit. Why are these capacitors there, and how do they work? Well, this fan is a Permanent-Split Capacitor (PSC) motor, which means that it has two windings, but unlike a split-phase motor, both of those windings stay in the circuit the entire time. The capacitor (or capacitors, in this case) are in series with one of those windings, and they are essential to the motor's proper operation. 3. How do the fan speed and position relays work? This circuit is set up cleverly so that, by simply opening or closing a relay, the motor can be run forward or reversed, and at two different speeds. How this is accomplished has to do with the polarization of the power supply and whether one or both capacitors are kept in the circuit. We cover all these elements of this motor and its circuit in detail in this recording. Watch the entire discussion below. These Live Dojo workshops are open to anyone, so keep an eye on our calendar to join in next one. Want to get in on the action? Join the Brotherhood of Techs at Appliantology. Appliantology.org is a cultivated, private community of techs. Get solid tech advice from working, professional techs and business owners. Avoid the endless noise and guesswork thrown at you from groups on social media. Download the service manuals, tech sheets, and service bulletins you need to git 'er done. Join the Brethren in the Craft right now with our membership options at Appliantology and see how it can help you in your business starting today.
  9. Today
  10. Budget Appliance Repair
    Crosley 24” elec range 2000? Model #?
    Don't know what you're using for model when looking it up but first try came up for me - XBS360DM2WW (Crosley Made by GE) here: https://www.a-1appliance.com/lookup/297930/2268979
  11. Manufacturer: IPSO Type of Appliance: commercial washing machine Model Number: BFNBCFSP112TW01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): y Hi wondering if the BFNB* results which I downloaded are correct for the IPSO BFNBCFSP112TW01 I have coming up. This is an older than 2015 according to the CX. Thanks very much as usual!!!!
  12. Hi, I am trying to fix a GE Monogram ZISS42DCASS side-by-side fridge where the freezer temperature only gets as low as 5 degrees F, and the fridge only gets to about 45 degrees F, with both of the temperature controls set to 9 (max). I have checked and cleaned the condenser coils and fan - all is good. I have checked the evaporator coils and they are clean with no ice build up. The defrost timer and heaters all seem to work well. The door seals are good and there are no obvious blockages with the airflow. I thought the freezer temperature control thermostat/capillary may be reading the temperature incorrectly. I bought a new part but before fully installing the capillary into the freezer section, I left it in the fridge and powered it on. The compressor ran and the freezer temperature went down to below zero. At that point I stopped and routed the capillary into the freezer section. Unfortunately the freezer then still only went down to 5deg. I then thought that maybe the evaporator fan was not blowing enough. I checked the fan and it blows well. The last though I had was to see if there was air getting to the fridge which is controlled by a capillary/damper. There seems to be adequate airflow in the fridge. After all of this, I am a bit stumped of what to try next. Does anyone have any suggestions? Thanks, John
  13. I have a 12-year-old Maytag Centennial Washing machine (model MVWC200XW3) that's not leaking or banging but it's very loud on the spin cycle. I Originally posted to Reddit but post got deleted so I reposted it onto here.
  14. I had an appliance repair company come out and troubleshoot. He strongly suspected it was the transmission and advised us just to run it until it dies because it'd be $400+ to get it replaced right now (almost half the cost of a new washer).
  15. Only see a tech sheet for this and uses the same one as this model:
  16. Yesterday
  17. Manufacturer: Frigidaire Type of Appliance: Refrigerator Model Number: GRFS2853AF Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I’m looking for the service manual for Frigidaire gallery refrigerator model GRFS2853AF. Help appreciated
  18. kokomo
    This mdl #er is not showing up anywhere online.
  19. Son of Samurai
    old thermador built in
    That model number isn't pulling up anything for me -- are you sure it's correct?
  20. Son of Samurai
    Samsung Wd53dba900hza1 service manual request
    Thanks, Cap!
  21. Samsung WD53DBA900HZA1 Laundry Combo Service Manual View File Pub Model Name : WD8000DK Model Code : WD53DBA900HZA1 Submitter Captain Dunsel Submitted 05/13/2025 Category Appliance Repair Manual Pot Luck Supper
  22. GE Dryer Personality Program Procedure WE22X34377 Part Install Instructions View File Pub 99-3000296 Submitter Captain Dunsel Submitted 05/13/2025 Category Appliance Repair Manual Pot Luck Supper
  23. GE Washer Personality Program Procedure WH22X33178 Part Install Instructions View File Pub 99-3000270 Rev 0 Submitter Captain Dunsel Submitted 05/13/2025 Category Appliance Repair Manual Pot Luck Supper
  24. GE Washer Personality Program Procedure WH22X38438 Part Install Instructions View File Pub 99-3000377 Rev 2 Submitter Captain Dunsel Submitted 05/13/2025 Category Appliance Repair Manual Pot Luck Supper
  25. GE Washer Personality Program Procedure WH22X31618 Part Install Instructions View File Pub 99-3000288 Submitter Captain Dunsel Submitted 05/13/2025 Category Appliance Repair Manual Pot Luck Supper
  26. GE Washer Personality Program Procedure WH22X37220 Part Install Instructions View File Pub 99-3000334 Submitter Captain Dunsel Submitted 05/13/2025 Category Appliance Repair Manual Pot Luck Supper
  27. LG LRYKC2606* Refrigerator Service Manual View File Pub MFL71894201 Rev 02 Submitter Captain Dunsel Submitted 05/12/2025 Category Appliance Repair Manual Pot Luck Supper
  28. LG LRYXC2606* Refrigerator Service Manual View File Pub MFL71894208 Rev 02 Submitter Captain Dunsel Submitted 05/12/2025 Category Appliance Repair Manual Pot Luck Supper
