Upcoming Events
Where: Online via Zoom
- Past hour
JenovaMk7 joined the community
MCW joined the community
- Today
mcline96 joined the community
Appliance Fixer 68 joined the community
suds1972 joined the community
Deus_Ex_Machina joined the community
Saved appliance joined the community
Follow up question to old Kenmore Refrigerator water inlet valve
lrubin28 posted a topic in DIY Appliance Repair Help
Kenmore Refrigerator model 10659212990. Water inlet valve 2206123. I bought a replacement water inlet valve 2206123. ...it's a triple solenoid model for a kenmore 10659212990. The incoming water supply goes to the brass nut - easy. But that's where I get confused. There's another solenoid (green) with a 1/4" port. I think this would go to the ice maker, and that's a 1/4" line that I can see running up the back of the fridge. So if I'm right, that knocks out 2 of the 5. So now I have 3 open ports on the 2206123 and they all appear to be 5/16". Coming from the fridge, there are 3 tubing lines bundled together before disappearing inside the fridge. 2 of them are 5/16" and the other is 1/4". How do I identify which tube goes into which port of the valve? (Unfortunately there are no documents on back of fridge or under front grate). It's an old fridge and no one seems to have any info on it. I'd appreciate it greatly if someone could help me out. Do I need to take the fridge apart to see where each of the 3 lines go? Hopefully not...thank you in advance... -
MrApplianceMatt started following Whirlpool WTW5000DW0 bearing repair? and Whirlpool front-loading automatic washer W10175588C not spinning up to full speed during spin cycle
MrApplianceMatt replied to bernk's topic in DIY Appliance Repair Help
It sounds like a few things might be going on but it's hard to tell from this video. The drain pump sounds loud so I would investigate that for a blockage or restriction. Check for any play between the spin basket and the tub as that would indicate a bearing or basket support arm failure. Pull the back panel off and look for signs of leakage from the basket drive shaft. There should be some technical information tucked under the top somewhere. I would look for error codes to see what the control board thinks is wrong and why it's limiting spin speed. -
MrApplianceMatt replied to Appliance Repair 60's topic in DIY Appliance Repair Help
This would require a gear box replacement. The gear box is self contained and is not designed to be rebuilt. It includes the tub seal. Is there any lateral play between the tub and the basket? If so, then this would require replacing the basket as well. These machines were designed for economy, not longevity. - Yesterday
b993 joined the community
Need service manual for GSS25GSHBCSS
drew 83 replied to drew 83's topic in Appliance Service Manual Requests Forum
Thanks! -
Appliance Repair 60 posted a topic in DIY Appliance Repair Help
I have a Whirlpool top load washer that has became rather loud on the spin cycle and I’m pretty sure it’s due to a bearing going out. Do they sell a bearing kit for this model? -
Request for Service Manual
Captain Dunsel replied to RHenterprises1223's topic in Appliance Service Manual Requests Forum
Uses the same tech sheet as this model:- 1 reply
- 1
RHenterprises1223 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Kenmore Type of Appliance: Electric Range Model Number: 790-94149310 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Please provide the service manual for Kenmore Electric Range model # 790-94149310 -
Kitchenaid Refrigerator Tech manual
Captain Dunsel replied to Dan the Appliance Man's topic in Appliance Service Manual Requests Forum
Uses the same tech sheet as this model: This troubleshooting Guide comes up: May have some similarities to Parts of this manual:- 1 reply
- 1
Dan the Appliance Man posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Kitchenaid Type of Appliance: Refrigerator Model Number: KRFC704FPS01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Need a tech sheet or manual, please. Thanks -
Uses this mini manual.No exact service manual but you can work off these! This one: This one: And this: -
drew 83 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: GE Type of Appliance: Refrigerator Model Number: GSS25GSHBCSS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual for GSS25GSHBCSS -
DWHD650WFP/01 service manual request
Uses this manual: Uses this bundle: -
New Appliance Service Manual added: Thermador DWHD650WFP/01 Dishwasher Service Manual
Thermador DWHD650WFP/01 Dishwasher Service Manual View File PUB 58300000211238 Submitter Son of Samurai Submitted 05/15/2025 Category Appliance Repair Manual Pot Luck Supper -
Manufacturer: Thermador Type of Appliance: Dishwasher Model Number: DWHD650WFP/01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need to request service manual/tech sheets for Thermador dishwasher model # DWHD650WFP/01 - Last week
Kenmore bosch 630.13953011 dw tech sheet please
Captain Dunsel replied to igloo's topic in Appliance Service Manual Requests Forum
This should work for you:- 1 reply
- 2
igloo posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Kenmore Type of Appliance: dishwasher Model Number: 630.13953011 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): y I need a tech sheet for a 630.13953011 dishwasher please -
At first it was doing this intermittently and we thought it was a balancing issue. Now, it's every time. Although the machine does spin, it never spins fast and the clothes come out sopping wet. Doesn't matter how big the load is. I've tested it with one or two T-shirts and it still doesn't spin. Any ideas? Also, what is it that engages and makes that noise at 0:22 in the video?
Midea Refrigerator E6 Error Code
StaggsHomeAppliance replied to StaggsHomeAppliance's topic in Appliance Service Manual Requests Forum
@Captain Dunsel thank you! -
79092583510 Frigidaire manual or wiring diagram
S & E Appliance replied to S & E Appliance's topic in Appliance Service Manual Requests Forum
Much thanks Captain!! -
TECH SHEET Request for KMCC5015GSS1 (KITCHENAID MICROWAVE)
leftbehind replied to leftbehind's topic in Appliance Service Manual Requests Forum
Thanks for the help. There only 3 switches, the top should be NO (Primary) and the middle should be NC (Second), and the last should be NO (Door sensing)? What puzzles me that all the switches were the same and it still works. -
Captain Dunsel replied to leftbehind's topic in Appliance Service Manual Requests Forum
No parts list, tech sheet comes up for this model on servicematters or anywhere.It is a good model number though! -
Manufacturer: Viking Type of Appliance: Under counter drawer microwave oven Model Number: Vmod5240ss Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need complete service manual
Captain Dunsel replied to StaggsHomeAppliance's topic in Appliance Service Manual Requests Forum
I look at the user manual and parts list and maybe this model would be close to what you have.Take a look!That's why I uploaded it. -
GE Washing Machine Schematic
Captain Dunsel replied to Peteralward_'s topic in Appliance Service Manual Requests Forum
I am not finding a parts site that identifies the mini manual for that model. Guessing maybe it is in this ball game!
Blog Entries
Topics
