Upcoming Events
- Past hour
Kenmore washer mod# 41748102701 tech sheet needed
Freddy B posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Kenmore Type of Appliance: Washer Model Number: 41748102701 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need the tech sheet for this washer so I can get it in diagnostic mode and tear it down to work on it. Thanks. washer does nothing at the moment. UI works but nothing else. - Today
bmwatts116 joined the community
leighbran joined the community
Skibidi joined the community
Whirlpool Gas Dryer Model WGD4815EW2 (2019) no heat/spin action, just noise
njose17 replied to njose17's topic in DIY Appliance Repair Help
Hi Brian. Just wanted to give an update. I replaced the belt (it had already snapped) and the dryer is working as it should. Very simple procedure putting in the new belt. Glad that's all it was. I actually had more trouble putting the front panel back in those little hooks and aligning the drum to the door at the same time. Thanks again for all the help! Truly appreciated! ps. And yes, I didn't forget to clean up inside the dryer. -
Whirlpool FG GI6FDRXXY010 Dispenser Assembly Disassembly Instructions
JSMequipmentservices replied to JSMequipmentservices's topic in Appliance Service Manual Requests Forum
Found a ton of videos on you tube it was simple sorry don't have a link. -
Wolf Tech joined the community
abdel started following SAMSUNG FRENCH DOOR REFRIGERATOR - Model RF26J7500SR/AA
Fassil joined the community
Budget Appliance Repair replied to qkcam's topic in DIY Appliance Repair Help
@DarkHorse96 Don't try it - you will never get them back together correctly. After you get the new one mounted by making a mounting bracket like I suggested and you know all is working OK - then try to take the old t-stat apart and see what you end up with. -
The smart HQ module and app don’t have the capability of updating the UI?
GFW850SPN0RS Reversed polarity at power cord
JPatt79 replied to murdrod's topic in DIY Appliance Repair Help
I know I’m late to this party, but just late night scrolling and came across this topic and wow! Has a service bulletin been released about this? Our local supplier here says the boards for these is the number two selling part in their warehouse, I’ve replaced two boards in the last two weeks on two different machines, now the gears are turning in my head because they were only four year old machines with very strange behavior. Haven’t heard back from either customer, only time will tell… - Yesterday
FGHD2465NF1A tech sheet
Captain Dunsel replied to fcm350's topic in Appliance Service Manual Requests Forum
@fcm350 Tech sheet is also in the same download as the parts list! -
Manufacturer: Fridgadare Type of Appliance: Dishwasher Model Number: FGHD2465NF1A Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Looking for tech manual to put the dishwasher in diagnostic mode. I found one on the parts but not how to put it into diagnostic mode. Customer said the error code was ER. Thanks for your help.
Jsmithack joined the community
Thank you.
mechtech repairs joined the community
Looking for service manual T411VDWU
drew 83 replied to drew 83's topic in Appliance Service Manual Requests Forum
Asko -
Frigidiare Ref mod: FGUS2642LF2
Captain Dunsel replied to Techonamission's topic in Appliance Service Manual Requests Forum
Try this also: -
natalielnyc joined the community
This doesn't come up for your model but try this.Frigidaire is horrible for service manual. -
Felixl57 joined the community
Techonamission replied to Techonamission's topic in Appliance Service Manual Requests Forum
can you provide the Service manual too please? This tech sheet doesnt have error codes -
Uses the same tech sheet as this model: -
Techonamission posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Frigidaire Type of Appliance: Refrigerator Model Number: FGUS2642LF2 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Requesting tech sheet for Frigidiaire ref mod: FGUS2642LF2 -
johnsavit replied to JSMequipmentservices's topic in Appliance Service Manual Requests Forum
Good question how does it come apart? -
Cafe slide in induction cooktop CHS950P2M2S1 not working, error code F360
allen63 replied to Craig1's topic in DIY Appliance Repair Help
What is a hestan pan? -
Thanks! That sounds like a viable alternative if I can't figure out how to use the actual mount off the original 10085. I did notice that there seems to be some kind of bend-over / crimp tag on the bottom 2 corners of both the original thermostat and the substitute. Has anyone tried to bend those tabs of a dead one to verify whether we could theoretically release both stats' mounts and securely attach the original mount to the 10085? Of course, I'd also be betting that the 10085's exterior mount will pull off an unseen underlying shaft because that big threaded region its shaft may be too long to fit under the old mount. -
drew 83 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Asko Type of Appliance: Dryer Model Number: T411VDWU Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for service manual, thanks! T411VDWU -
LG Combo Washer/Dryer WM6998HBA Service Manual & Parts Diagram Needed
FLAppliances replied to FLAppliances's topic in Appliance Service Manual Requests Forum
Thanks Vance! You’re the man! -
Son of Samurai replied to Wayne Moore's topic in Appliance Service Manual Requests Forum
Thanks, Vance! Approved. -
New Appliance Service Manual added: LG WT8480CL Washer Service Manual
Vance R posted a topic in Appliance Service Manual Requests Forum
LG WT8480CL Washer Service Manual View File PUB MFL69647043 Submitter Vance R Submitted 06/08/2025 Category Appliance Repair Manual Pot Luck Supper -
Son of Samurai replied to FLAppliances's topic in Appliance Service Manual Requests Forum
LG WM6998HBA Washer Dryer Combo Service Manual View File PUB MFL71873719 Submitter Vance R Submitted 06/08/2025 Category Appliance Repair Manual Pot Luck Supper
Blog Entries
2 comments
Topics
JSMequipmentservices · Started
