Upcoming Events
- Yesterday
Darci joined the community
Ryan Repairs started following Looking for Mentorship and/or Shadowing Opportunity in Dallas, TX
Hi Appliantology Community, I’m a recent graduate of the Appliantology Core Appliance Repair course and am currently working through advanced modules (e.g., refrigeration, washer/dryer, stove/oven repair, etc.). I’m eager to gain hands-on experience and apply what I’ve learned. I’m looking for an experienced technician in the Dallas area who would be open to letting me shadow them on weekends and/or evenings. My goal is to learn the ropes and gain real-world experience to complement my training. I’m detail-oriented, committed, and open to transitioning to part-time work once I’ve gained more experience. If you’re open to mentoring or know someone who might be, I’d love to connect. Please feel free to send me a message to discuss further. Thank you, Ryan -
Kmhogan joined the community
Inqo joined the community
Eng89 joined the community
NPerry joined the community
jumpinjax joined the community
But what about the really loud sound on spin cycle. It’s like a jet engine in our laundry room (very loud). -
Jose Rodriguez joined the community
- Last week
Captain Dunsel started following Tech sheet needed
Tech sheet needed
Here you go: -
Any updates? Need it too
Robert Couchman started following B21CL81SNS/04 compressor control board failure
Thanks, Captain! -
T18ID905LP/11
Manufacturer: Thor Type of Appliance: Range Model Number: FFSGS6291-36 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yea Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need to request service manual for Forno range model FFSGS6291-36 -
service manual above -
Hi, it had a manufacture defect and i had to change the position of the evap thermistor. call their tech support, they are very helpful -
GE CleanSpeak Washer Control Board Personality Part Instructions WH12X21454,WH12X20504,WH12X20500,WH12X20503,WH12X20500,WH12X25674,WH12X25675 View File Pub WH00X5617 Submitter Captain Dunsel Submitted 06/27/2025 Category Appliance Repair Manual Pot Luck Supper
Thermador VTR1400Q, VTR1000Q & VTR600R Roof or Wall Ventilator Installation Manual View File Includes wiring diagrams and installation instructions for these wall and roof mounted vents used as range hoods in combination with static range hoods and static vent tubing. Thermador ROOF OR WALL VENTILATOR MODELS: VTR1400Q VTR1000Q VTR600R Submitter Ananda Submitted 06/26/2025 Category Appliance Repair Manual Pot Luck Supper
Captain Dunsel replied to David Hare's topic in Appliance Service Manual Requests Forum
Uses the same tech sheet as this model:- 1 reply
- 1
David Hare posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Kenmore Type of Appliance: Dryer Model Number: 11068002010 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes -
Ge washer gtwn7450d0ww control board programming
Captain Dunsel replied to johntech's topic in Appliance Service Manual Requests Forum
Looks like 5.- 1 reply
- 1
Blog Entries
2 comments
Topics
