Upcoming Events
07 June 2025 02:00 PM Until 03:00 PM
Where: Online via Zoom
- Today
Jesui joined the community
D3vin joined the community
Video - FIRST USE - Making Better Hose Clamp Pliers, Pt. 4 - First Blood
Rhubarb Tau commented on Rhubarb Tau's blog entry in Rhubarb Tau's Sloggy Vlog Blog Bog
I'll have some more made soon, as soon as I troubleshoot the cutoff tool on my little shitty metal lathe. I think I'm going to sell a few to fellow techs for $50 plus shipping. I don't have a merchant site set up yet, but should soon. If you're down, you're on the list! -
Manual Needed for SHE878WD5N/01 or a manual that's compatible
McLoughlin132 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHE878WD5N/01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES . -
Service Manual needed for Bosch Dryer WTG86402UC/01 - not sure if the manuals already listed are compatible with this model
McLoughlin132 replied to McLoughlin132's topic in Appliance Service Manual Requests Forum
Sorry for the late reply @Son of Samurai but thank you so much. Really appreciate it! -
drew 83 started following Need service manual and Need service manual
Manufacturer: Deco Type of Appliance: Dryer Model Number: 860 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual
Manufacturer: Deco Type of Appliance: Washer Model Number: 824 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual.
Mykola Zaytsev joined the community
Whirlpool refrigerator bottom freezer (Model GB2FHDXWB02) fridge warm freezer cold
matty1stop posted a topic in DIY Appliance Repair Help
So yesterday I moved my refrigerator to paint behind it. I didn't unplug it or anything, just moved it forward so I could get behind it and then pushed it back. This morning the fridge was warm (about 60 degrees pretty close to room temp). I think the fridge is about 14 years old. The last time this happened, maybe 6 months ago I vacuumed the coils and it seemed to fix it. The coils don't look bad this time. I replaced the control board a few years ago. Someone suggested replacing the wiring harness and defrost thermostat at one point. It looks like that part (WPW10290745) can range from $65 - $200. Given the age of the appliance, is it worth it to try to replace that? As always, your advice is greatly appreciated. Thanks, Matt -
LowCountryAppliance joined the community
- Yesterday
Captain Dunsel started following GE in wall oven ZEK7000SH1SS
Captain Dunsel replied to RChase's topic in Appliance Service Manual Requests Forum
No exact service manual for this one.Look at this one: Also look at this one: Uses this mini manual: -
RChase started following GE in wall oven ZEK7000SH1SS
Manufacturer: GE Type of Appliance: In wall oven Model Number: ZEK7000SH1SS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I have a ZEK7000SH1SS and the door latch died after self-cleaning. I would like a service manual that shows disassembly. Thank you.
rchdesk joined the community
Whirlpool Top Load Washer and Stacked Laundry Service Pointer - F3E1 Pressure Sensor Error or Drain Pump Running Continuously S Code: S153EB View File Problem: F3E1 error code (pressure system fault) or drain pump continuously running. PUB W11766193 Rev C Submitter Samurai Appliance Repair Man Submitted 06/02/2025 Category Appliance Repair Manual Pot Luck Supper
Samurai Appliance Repair Man posted a file in Appliance Repair Manual Pot Luck Supper
Kenmore FG 596379243017 SM Request
Captain Dunsel replied to JSMequipmentservices's topic in Appliance Service Manual Requests Forum
Jeffin NC joined the community
Kenny Oliva joined the community
Ernesto joined the community
Manufacturer: Kenmore Type of Appliance: Refrigerator Model Number: 596.379243017 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes -
Need tech sheet for Sub Zero UW-24/S/PH-RH
DStenoien posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Sub Zero Type of Appliance: Refrigerator Model Number: UW-24/S/PH-RH Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I need a tech sheet or service manual for this unit. Thank you -
Did you end up resolving this? I am battling same issue now. Replaced main board behind grill with no success. The failure is intermittent which makes this nearly impossible to diagnose. I was planning to replace either the UI board, the inverter board, or both...
Congratulations to our June 2025 Super Tech: Rhubarb Tau!
Samurai Appliance Repair Man replied to Son of Samurai's topic in Announcements
Absolutely an Appliantology Super Tech! And be sure to check out Rhubarb's blog. Filled with all kinds of tech geekery that all appliance techs would be interested in: -
Service manual request WAT28400UC/14
drew 83 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Bosch Type of Appliance: Washer Model Number: WAT28400UC/14 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual request WAT28400UC/14 -
Rhubarb Tau replied to Son of Samurai's topic in Announcements
Holy Shit! You'll bleep that, right? I don't know what to say! Thanks everybody! I'll do my low-grade best to live up to this terrific honorific! -
Looking for the Service Manual for the DD24DDFX7 Fisher&Paykel dishwasher.
Adrian_C replied to Adrian_C's topic in Appliance Service Manual Requests Forum
Thank you! -
timswc joined the community
Koi Guy commented on Rhubarb Tau's blog entry in Rhubarb Tau's Sloggy Vlog Blog Bog
I want one! -
LGtech23 joined the community
[Free] Errors, Omissions, and Dummy Directions in Service Manuals
Koi Guy replied to Son of Samurai's topic in Featured Free Workshop
Good one Sam!- 1 reply
- 1
Koi Guy replied to Son of Samurai's topic in Announcements
Congrats Rhubarb! -
Son of Samurai posted a topic in Featured Free Workshop
We hope you enjoy this free workshop and that it helps make you a better appliance tech. This workshop will be available to the public for free through this month. After that, we'll remove this one and post a new free featured workshop selected from our vast repository of appliance repair training workshop videos. If you're currently a professional appliance repair tech, these workshop videos will improve your understanding of electric circuits and appliance technology and up your troubleshooting game. If you're a DIYer or considering getting into the appliance repair trade (great choice!), these workshops will kick your training into high gear. If you would like a more structured, step-by-step, training experience, enroll today at the Master Samurai Tech Appliance Repair School. One of the benefits of enrolling at Master Samurai Tech is that you get a free 6-month professional membership here at Appliantology which gives you access to all the workshops, the tech forums, and the service manual downloads. If you get certified in our Core Appliance Repair Training Course, you get a free annual professional membership at Appliantology. See details on this page. Now, on to the workshop! ---------- What do you do when even the service manual can't be trusted? In this video, we discuss how to deal with bad or missing information in all kinds of tech docs -- service manuals, tech sheets, schematics, you name it. Topics covered include: Pin numbering discrepancies Reconciling pinouts with schematics Identifying power supplies Recognizing incoherent specs What are dummy directions? ..and more! Your webinar presenter is Sam Brown. I’ve accompanied my dad on service calls since I was old enough to hold the meter for him, and my role in our business has only grown since. As I grew up, I ran daily service calls with him as my fulltime job and did lots of troubleshooting out in the field. Proud to carry on the tradition of mastery in my family, I wear a lot of hats. On top of being the Team Samurai IT guy, I teach, help write coursework, and write blog posts on technical topics. I’m also the Admin at our tech support site, Appliantology.org, and I’m always at work behind the scenes to make sure all our websites are running in tip-top shape. I have also helped the team develop content for the Advanced Washer and Dryer and the Advanced Oven and Range courses.- 1 reply
- 2
Son of Samurai posted a topic in Announcements
Our latest Super Tech is a seasoned veteran of the Appliantology forums: it's the ever-helpful @Rhubarb Tau! Congratulations, Rhubarb! You've got a fancy, exclusive badge on your profile page to show off your Super Tech status. Thanks for all the time and wisdom you share with us here at Appliantology -- it's techs like you who make this site the great place it is. Our next Super Tech will be decided by you all in the replies to this post! So along with giving Rhubarb Tau your congratulations, discuss who you think deserves to be the Super Tech for July 2025. -
Service manual needed: Thermador DWHD770WFM/17
Son of Samurai replied to nwjudge's topic in Appliance Service Manual Requests Forum
Here you go:- 1 reply
- 1
New Appliance Service Manual added: Thermador DWHD770WFM/17 Dishwasher Tech Bundle
Thermador DWHD770WFM/17 Dishwasher Tech Bundle View File Service manual PUB 58300000218464 Service mode PUB 56000000183974 Error codes PUB 58300000225016 Schematic PUB 58309001490564 Submitter Son of Samurai Submitted 06/01/2025 Category Appliance Repair Manual Pot Luck Supper
Blog Entries
2 comments
Topics
matty1stop · Started
