  2. Today
  3. Uploading mini manual and waiting on approval:
  4. I took your advice and fabricated a mount for the substitute thermostat. But when I tried to find a nut that matched the threaded part of the shaft on the WR50X1008 to attach that mount, I've been unable to find any nut that will fit that thread. When i put a micrometer on the OD of the threads, it's slightly less than 3/8". So I first tried nuts for standard 3/8"nuts starting with standard 3/8" thread, fine-thread 3/8", and extra-fine thread 3/8. No joy. The closest metric seems to be M10. So I also tried nuts for M10 - 1.00, M10 - 1.25, and M1 - 1.50. None of the above would screw onto that shaft. (All the nuts I was trying were standard right-hand / clockwise to tighten thread rather than reverse / left-handed thread). Since I bought that thermostat on the "GE Store" of Amazon, I tried calling GE Customer Support. But all I got was a circular run-around with no chance to ever talk to anyone that might provide the thread spec. Does anyone have any idea what kind of nut threading would fit on the threaded part of that shaft? Imperial / Metric? Left-hand, right-hand thread? Some kind of tapered shaft? Some oddball, in-between-standard sizes thread? Etc. Thanks in advance for anyone that can point me in the right direction to get a nut that will fit and allow me to attach my mount?
  5. Manufacturer: GE Type of Appliance: Cooktop Model Number: PP912KM2CC Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Tech sheet and/or wiring diagram or schematic
  6. Captain Dunsel
    Hisense Refrigerator
    @TurtleRock Check your private messages!
  7. TurtleRock
    Checking to see if manual has been uploaded.
  8. Manufacturer: LG Type of Appliance: Washer Model Number: WM2450HRA Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual, thanks!
  9. Manufacturer: Bosch Type of Appliance: Diswasher Model Number: SHE43M05UC/50 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hello. I need the service manual for this dishwasher. Please help. Thanks brethren
  10. @Mesaman2124 Check your private messages!
  11. @Captain Dunsel Thank you, I will take a look. Yes, having a drain problem. It does not throw the error code until 40-50 minutes into a wash cycle, at the end of wash cycle before it goes into a post rinse, I've had to check the chart to say for certain but when that happens it resets the control and kicks you out of the cycle. The drain pump is working and it seems to be draining well but possibly just barely above the port for the pressure sensor. Based on the service manual, we'll be looking at drain hose with check valve and then drain pump?
  12. @Mesaman2124 Not sure that TB11-20 service bulletin exit? I guess you have a Drain problem.I believe your model uses the same pressure sensor talk about in this old thread.Take a look!
  13. Looks like the main igniter for baking went out. Only glows a dim orange color and will not allow gas to flow. Looks like a pretty easy repair but the parts pricing is all over the place. From an OEM igniter costing over $140 down to an aftermarket costing like $30. Was thinking of going aftermarket...any thoughts ??
  14. Yesterday
  15. Manufacturer: GE Type of Appliance: Dishwasher Model Number: GDT665SGN3WW Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for GE training bulletin TB11-20. This bulletin is referenced in the full service manual for dishwasher model GDT665SGN3WW regarding testing for error code 56. Please help. Thank you.
  16. Captain Dunsel
    Bosch Dishwasher MOD: SHPM78W55N/11
    You should be able to use this: This schematic: And this:GV640 Platform Dishwasher Fault Chart with CS Test Program 58300000190152
  17. Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHPM78W55N/11 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Requesting tech sheet/service maual for Bosch DW mod: SHPM78W55N/11
  18. Captain Dunsel
    LG fridge manual needed
    Here you go:
  19. Manufacturer: LG Type of Appliance: Fridge Model Number: Lcfc26xss Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Does anyone have the tech manual for this?
  20. Captain Dunsel
    Service Manuel Request
    Uses the same mini manual as this model:
  21. Manufacturer: GE Type of Appliance: Electric Range Model Number: JB258GM1SA Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes The two large cooktop elements aren’t getting red hot. I measured 240Vac at the element plug-in. I need to know the resistance of the two large cooktop elements.
  22. Thank you.
  23. Rhubarb Tau
    GE GDT226SSL0SS Dishwasher Mini Manual
    Also applies to mod. GDT225SGL0WW , and prolly many others
  24. until
    All are invited to join in the conversation for all things Appliantological: bidness, customers, tools, troubleshooting, flavorite brewski, whatever. Webcams and microphones are open and live! Also, follow this Calendar Event so you'll get notified of new posts here. Look for the "Follow" button either at the top of the topic on desktop or below the topic on mobile. Who: This workshop is available to everybody, including you! You don't have to be a member of Appliantology to join the fun. When: Saturday, June 28 @10:00 AM Eastern Time. Where: Online via Zoom How: Click here to register. If you're interested, register now. Arrive a couple minutes early to make sure your connection is working. Set a reminder for yourself for this workshop so you don’t miss it.
  25. Captain Dunsel
    Uploading service manual and waiting on approval:
  26. Yeah, getting those lower clips to line up and engage while keeping the drum in place can be fun if you've never done it before. Once you do it a couple hundred more times it gets easier. !! Glad you got it going. Good for another 3000 miles!
  27. Manufacturer: Hisense Type of Appliance: Refrigerator Model Number: HRT180N6AWD Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Unit will not go into defrost cycle. Need tech Sheet or service Manual Thanks
  28. d915byrd
    Service manual needed
    Thanks again
