  1. Today
  2. Is this the correct manual @Vance R? The front page says it's for this model series: MODELS : W3S1*
  3. Yesterday
  4. Manufacturer: GE Type of Appliance: RANGE Model Number: JGB760EEF2ES Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES JGB760EEF2ES Service Manual Please
  5. You should be able to use this:
  6. Manufacturer: Samsung Type of Appliance: Stacked washer & dryer Model Number: WH46DBH500EVA3 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes
  7. Here you go:
  8. Manufacturer: Whirlpool Type of Appliance: Electric Wall Oven Model Number: WOS92EC0AS01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Just looking for tech sheet thanks!
  9. I know I'm resurrecting a dead thread, but this is my first time working on one of these units and I cannot for the life of me get the adc board and housing out from where it's wedged in to the condenser. Am I just dumb, or is there some sort of secret trick to removing these? I see the tab on the top lid that clips it in place, but I cannot depress it and remove the box at the same time.
  10. Daniel Yanovski
    Freestanding Electric Range
    Perfect Thank You
  11. Captain Dunsel
    FGIP2479SF1A Service Manual
    Uses the same one as this model: @Ken King This also comes up:
  12. Manufacturer: Frigidaire Type of Appliance: Dishwasher Model Number: FGIP2479SF1A Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes FGIP2479SF1A Service Manual Please
  13. Captain Dunsel
  14. Manufacturer: Whirlpool Type of Appliance: Range Model Number: YWEE515S0LS0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hi can you please help me to find service manual
  15. In case it helps anyone: I solved the issue of the foam getting waterlogged by coating it in Flex Seal. I also coated the drain pan and increased the angles, so the water drains away immediately. I checked after running the unit for over half a year and everything looks great.
  16. I found out (by accident) that the unit runs the evap fan in the fresh food compartment in some special case and otherwise not. When it runs in this special case, the humidity rises. Normal case is fan runs for a few minutes after compressor turns off and then turns off until the next cooling cycle. The special case is that the fan turns back on after some time and stays on until the next cooling cycle. I noticed the thermistor on the coil was out of spec and replaced it last year, but it didn't solve this issue. The other thermistor on the cabinet wall appeared to be in spec, but, perhaps, it's slightly out of spec? Might it read a tad too cool?
  17. vee8power
    To disassemble, watch this video first and be careful not to break that little tab on the spray arm base. Assuming the dishwasher is level so the water isn't just sitting in a different part of the tub, there are 2 things to check. There must be a high loop in the drain hose under the sink before it empties into the disposal. The other thing lately that causes incomplete draining on these is the rubber sump swells up and doesn't form a seal with the filter. It's the round part at the bottom of this upside-down picture where the check ball goes that causes the issue.
  18. Last week
  19. joshua_trees
    Thank you!
  20. It took a good bit of time to identify that thread, but I eventually found it to be an "electrical panel" thread; not a regular M10 "standard, fine, or extra fine" thread. From what I understand, many appliances need relatively thin nuts to fit into tight spaces and need VERY fine threads to hold securely without requiring a much thicker nut to have room for enough threads for the required holding power. That's why in my initial testing even standard M10 "extra fine" nuts were too coarse for that thermostat. Those threads are specified by a adding a specific thread pitch in mm. Besides their use in electrical panels, appliances, lamps, etc., such thread pitches are also commonly used in panels on cars and trucks. That particular thermostat's threaded area is an M10 x 0.75mm thread. (M10 "extra fine" thread is only M10 x 1.0mm). I bought a small bag of M10 x 0.75, steel, metric hex nuts that are thin (only 2.6mm high) on Amazon. They screwed right on to the thermostat's threads with no issues. A 60-count bag was only $7.89. (There are other offerings for them, but I bought the first one I saw that I could next-day Prime in). Just bring up Amazon and type the ASIN (Amazon Stock ID Number) "B0CN2JNVXF" into the search box and click the Search symbol. (Or, if you'd rather search by spec than ASIN, the listing for the bag I bought had the listing title: "PATIKIL M10x0.75 Steel Hex Nuts, 60 Pack Metric Thread Zinc Plated Finished Hardware Nuts Screw Bolt Fasteners for Lamps Machinery Repair 2.6mm Height"). I've been working higher priority projects and haven't yet had time to go back to the chest freezer repair, but this should allow me to mechanically attach a mount to the 10085.
  21. Glad you got it going. Surprised you were still able to find a timer. Good for another 3000 miles!
  22. Pull off the spray arm, take out screw and remove filter ring. Pull sump cover and clean it out. Check ball inside, clean it as well. If not clear to you, look up exploded view or service manual. This dishwasher does not have a drain pump. The main pump does the draining when the drain valve solenoid is activated.
  23. FIXED IT! Turns out Repair Clinic had 2 different timer motors listed as being compatible with this model originally, Originally I was able to find one of these two to replace the timer motor with. Finally was able to track down the other model number listed originally on RC and found a NOS one - this looked identical to the other timer motor, except for the model number stamped on it. This one works, and the dishwasher now drains out at the end of the cycle, as it did before, but now the motor and arms do not continue running while the DW goes into the drying mode!
  24. Vance R
    Lg dishwasher
  25. Sorry, I realise now there is one available. I think I didnt set the proper search area focus before trying, after my search of another model number.
  26. Manufacturer: Fisher & Paykel Type of Appliance: Dishwasher Model Number: DD24DCTX6 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Fisher & Paykel DD24DCTX6 dishwasher service manual request Thank you
  27. Just to add some closure to this thread. The extended hose didn't work too good. I bought the updated sensor from Bosch. I separated the housing, drilled a hole in the housing so i can turn the screw with the housing back together. The new sensor alone (without touching the screw) allowed for a higher water level on all cycles. I'll still be experimenting with the screw to achieve a little more water so I can see it in the door seal gusset. Not looking for much water because I know it puts wear on parts- shocks, springs, motor, spider bracket, etc.
  28. Still nothing at LG web site for this refrigerator.
