  2. Today
  3. Thanks, got the floodstop unit (new, replaced ancient one) fixed - turns out some of these new units were installed with the gears backwards in the motor, so when you hit closed, the valve would open, and open the valve would close - so when you poured a bit of water on the sensor, it would OPEN the valve and not CLOSE it as it should - victory! So now on to try to get the stove apart enough to take a pic of the thermostat to see if it is rebuildable or not, the company that rebuild my gas safety valve said it may be too current of a model to be rebuildable, but worth a shot to see a pic. If not, then it looks like I will be looking at going your way with trying to find a replacement. It is surprising to me that since they made these stoves with standing pilot until just a couple of years ago that a modern replacement thermostat would not work, now they are all electronic ignition.
  4. ATOSA MBF8000 Series Vertical Coolers and Freezers Instruction Manual View File Instruction manual for ATOSA MBF 8000 series vertical cooler/ freezer Submitter d915byrd Submitted 05/28/2025 Category Appliance Repair Manual Pot Luck Supper
  5. Son of Samurai
    Thermador range
  6. Son of Samurai
    Thermador cooktop
    Here you go:
  7. Thermador PC486GDBS/01 Cooktop Schematic View File PUB 58300000103877 Submitter Son of Samurai Submitted 05/31/2025 Category Appliance Repair Manual Pot Luck Supper
  8. Version 1.0.0
    0 downloads
    PUB 58300000103877
  9. Captain Dunsel
    Thermador range
    Looks like you can use this:
  10. Sorry for the delay on this one -- here it is:
  11. GE Front Load Dryer Main Board Programming Part WE22X39117 install Instructions View File Pub 99-3000285 Rev. 2 Submitter Captain Dunsel Submitted 05/30/2025 Category Appliance Repair Manual Pot Luck Supper
  12. Kenmore 970-C97912-10 Laundry Center Parts List and Wiring Diagram View File Pub 5995501227 Submitter Captain Dunsel Submitted 05/29/2025 Category Appliance Repair Manual Pot Luck Supper
  13. GE GBVH6260 Washer Mini Manual View File Pub 31-15581 Models: GBVH6260 GCVH6260 WCVH6260 WBVH6240 WHDVH626 Submitter Captain Dunsel Submitted 05/29/2025 Category Appliance Repair Manual Pot Luck Supper
  14. Is the condenser fan running/getting power? Can't transfer heat without that running with the compressor with the back cover on and attached. Take a picture of the evaporator while it's been running awhile. If compressor is running what's the amp draw?
  15. Nathaniel Peterson
  16. Yesterday
  17. Nicholsseand
    Frigidaire Range Tech sheet please
    Thanks Captain!
  18. You can use this service manual: Looks like a stand alone ice maker! Uses the same tech sheet as this model:
  19. Captain Dunsel
  20. @Peteralward_ Check your private messages!
  21. @Captain Dunsel Any word on the approval? Sorry just a little worried because I have to be at this call in 45 minutes and they're having a strange electrical problem. Thanks team
  22. Manufacturer: Frigidaire Type of Appliance: Fridge` Model Number: GLHS37EHSB6 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes I would love to find the service manual for this fridge. Or any info on troubleshooting the ice maker in it. Part #: 241798231 Service mode for testing the ice maker, wiring diagram for it.
  23. Manufacturer: Frigidaire Type of Appliance: Stove Model Number: FFEF3012LWD Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Looking for any info on this one. All I could get was pulled back to FFEF301* . Curious if there is something out there more relevant. Thank you!
  24. Manufacturer: Thermador Type of Appliance: Range Model Number: PRG364WDH/01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Need tech sheet and proper wiring diagrame
  25. Captain Dunsel
    Request for Service Manual
  26. Manufacturer: Thermador Type of Appliance: cooktop Model Number: PC486GDBS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES Need tech sheet for this unit
