  1. Today
  2. My fridge the other day was getting salad greens icy at back of fridge. To be honest, fridge was completely packed. This morning, freezer contents were defrosting, even though LED for freezer said -2. Clearly NOT -2 in freezer if ice cream melting. I cleared out stuff from fridge and freezer. Ran a blow dryer in back of freezer to make sure no ice. Unplugged fridge, waited, plugged back in. LED then read 46 for freezer when I plugged back in…but after a while, eventually went back down to -2. But thermometer in freezer reads much warmer. Can the ok LED temp shown be wrong? When I put my hand inside freezer, it doesn’t seem as cold as LED reading. (Inside fridge temp is same as LED reading 38) The refrigerator section seems to be working fine. How long, if freezer components working properly do I have to wait for freezer temperature to be correct? (since I’ve been constantly checking the freezer, the LED temp has risen to 1. But Taylor old fashioned thermometer inside freezer reads 30—which is 16 degrees lower than LED read when plugged back in) By the way, I can hear refrigerator is running. I am just trying to determine if this might be on the road to recovery or get help…which on this holiday weekend might be impossible! thanks.
  3. will check, thank you.
  4. There is really no exact manual for this! Uses the same wiring diagram as this model: Indoor ice maker: This may not apply but here you go:
  5. Manufacturer: Kenmore Type of Appliance: Refrigerator Model Number: 10656546400 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for complete service Manual and tech sheet for 10656546400 , Thank you!!
  6. Couldn't agree more with this! Great job @Nathaniel Peterson! You've certainly earned this badge, and I continually enjoy reading your input on the forums. You've got a lot of sound knowledge, wisdom and experience!
  7. Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHS43CF5N/01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for diagrams, etc. to help with a not powering on issue. Will light up on breaker cycle, 5 seconds, then go out and won’t power on. SHS43CF5N/01
  8. It is possible that it is bad. The specs may have something you can find for a resistance check. I've never herd of the shifter causing the no lock issue before, but its either gonna be lid lock or board. Veryfi that its getting power from the controller. if its powered and not locking then switch, if your seeing drops in power when it should be locked then board.
  9. Casualcamo
    Have you looked at any fans?
  10. Casualcamo
  11. Casualcamo
    Tech needed in Hammond La
  12. Nothing here!
  13. Not that I could find.Uses this tech sheet:
  14. Captain Dunsel
    Tech sheet
    Uploading tech sheet and waiting on approval:
  15. Budget Appliance Repair
    @bldn10 Well...... That would certainly cause your problem - Glad you finally got it figured out.
  16. Budget Appliance Repair
    I would still be concerned about those capacitors - I don't think that is glue to hold the capacitor to the board. I think it's the guts of the capacitor that have leaked out possibly).
  17. I have a 4 year old whirlpool wrf555sdfz french door refrigerator. Noticed ice maker not making ice. I changed the water filter, water pressure increased and I was making ice. Then noticed the refrigerator was getting too cold (freezing my beers). Getting to about 25 degrees. I cleaned the coil and fan underneath (I removed front grill and back cover, vacuumed and blew the dust out). I am getting ice bucket temperature of 14 degrees. The bottom freezer is getting a steady temp of -4. I have the refrigerator temp set to 37 and freezer set to -5. The refrigerator temperature appears to be stabilizing around 36 degrees. But getting very little Ice. I read that I need to be at 10 degrees in the ice bucket to make ice. I have read about an issue with the ice maker filler tube freezing up. So I entered diagnostic mode , test 38 (forced defrost) and changed it to "Lo" for long defrost. Also the refrigerator seems to run all the time. I wake up in the morning and its running after the doors have been shut for 7 hours. Let me know if there is something else to try
  18. Waher lid would not lock, so i replaced it with a new one. I read that the shift actuator may be the problem so i changed it as well. when is pluged in the machine the lid lock begian to click on/off and would not start the machine. the last error code showed F5E3 which is a lid lock error. Is it possible that the new lid lock assembly is bad? what shoul i be looking for? thanks for your advice.
  19. ecappliancecompany
    Tech sheet
    Manufacturer: Kitchenaid Type of Appliance: Refrigerator Model Number: Krfc300ess07 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Tech sheet unit not keeping consistent temperature
  20. Nathaniel Peterson
    Thank you! You all did a great thing for the trade with this site. Including all the contributions from other fellow Appliantologists.
  21. Yesterday
  22. Manufacturer: Frigidaire Type of Appliance: French door refrigerator freezer Model Number: Grfc2353af0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hi I was looking for a possible full-service manual or tear down guide to see how to disassemble the freezer section so I can get to the defrost heater. Thank you
  23. Manufacturer: Insignia Type of Appliance: Dishwasher Model Number: NSDWH1SS9 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Insignia NSDWH1SS9 dishwasher service manual request Thank you
  24. Most of you guys are probably not on here anymore but I wanted to give an update, only 65 months later! I am going to have some work done on my 33 year old house to get it in marketable condition should I want to move. So I was thinking about this range, that still does not work right, and if I should replace all the Kenmore Pro appliances. The fridge has never worked right either; only the DW has been trouble-free. So I reviewed this thread and made some notes about what I have tried over the years. I have spent over $800 on parts including temp sensor, relay board, control board, lower element, etc. Just the other night I wanted to warm up some BBQ ribs and next thing I knew they were sizzling. WTF? So I was perusing the Service Manual this afternoon and something hit me - an illustration of the oven control knobs showed them reverse of my range! Well I'll be, somehow the mode selector and temp knobs got put on wrong. When I thought I was setting the temp I was actually setting a mode. What I thought was Bake at 400* was really Conv. Roast at 275. No wonder it would not get "over 250." I'm not sure this fixes everything because I haven't done any testing but at least now what testing I do will be accurate and not so confounding.
  25. We hope you enjoy this free workshop and that it helps make you a better appliance tech. This workshop will be available to the public for free through this month. After that, we'll remove this one and post a new free featured workshop selected from our vast repository of appliance repair training workshop videos. If you're currently a professional appliance repair tech, these workshop videos will improve your understanding of electric circuits and appliance technology and up your troubleshooting game. If you're a DIYer or considering getting into the appliance repair trade (great choice!), these workshops will kick your training into high gear. If you would like a more structured, step-by-step, training experience, enroll today at the Master Samurai Tech Appliance Repair School. One of the benefits of enrolling at Master Samurai Tech is that you get a free 6-month professional membership here at Appliantology which gives you access to all the workshops, the tech forums, and the service manual downloads. If you get certified in our Core Appliance Repair Training Course, you get a free annual professional membership at Appliantology. See details on this page. Now, on to the workshop! ---------- This electric dryer has error codes that claim to be able to show whether the heater has gone open or is grounded. It turns out that the control can in fact sense this, and the way that the engineers pulled this off is both simple and tricky to wrap your head around. Watch us break it down for you... Topics covered include: Voltage measurements in a control board How the reference affects voltage measurements in a 240 VAC circuit How a very high resistance load impacts a circuit Why a triac would be used to switch a heater ...and more!
  26. I love hearing Nathaniel's opinion. His suggestions are solid. Also his voice sounds like a friend of mine's. Another down to earth person.
