Upcoming Events
Where: Online via Zoom
- Past hour
Thankyou !!!
- Today
Budget Appliance Repair replied to SVeig's topic in DIY Appliance Repair Help
Model/Serial number tag will be on the bottom left side near the front Good luck in finding any available parts - good machine to keep going if part needed can be found. -
Captain Dunsel started following Need service manual for SWNBC2PP112TW01 and David Hare Need tech sheet/manual
Captain Dunsel replied to David Hare's topic in Appliance Service Manual Requests Forum
Uploading and waiting on approval: -
I see this trouble shooting guide: -
Vance R started following LG Styler Steam Closet Service Manual and Need service manual for SWNBC2PP112TW01
drew 83 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Alliance Type of Appliance: Washer Model Number: SWNBC2PP112TW01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for service manual, thanks. -
Edwin Birriel joined the community
Manufacturer: Dyson Type of Appliance: Vaccum Cleaners Model Number: Dyson SV46 Dyson SV47 Dyson SV25 Dyson SV28 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): NO Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I am writing to kindly request the Battery Management System (BMS) manual for a Dyson vacuum cleaner. I would greatly appreciate it if you could provide the relevant documentation or guide me to where I can access it. If needed, I can provide the specific model number of the vacuum cleaner to ensure the correct manual is shared. Thank you in advance for your assistance. I look forward to your response.
David Hare posted a topic in Appliance Service Manual Requests Forum
Manufacturer: WHIRLPOOL Type of Appliance: Refrigerator Model Number: EL88TRRWQ03 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes -
dodige joined the community
zergling29 joined the community
william Kennet joined the community
Vance R replied to candpappliance's topic in Appliance Service Manual Requests Forum
Uploaded service manual pending approval: -
Gordy joined the community
MrApplianceMatt started following 3 Wire Lid Lock or Control Board Issue
MrApplianceMatt replied to kerry H's topic in DIY Appliance Repair Help
What pins are you checking? If you're checking between 2 and 1 or 2 and 3 in connector J13 the you're going to see 120 VAC because J13-2 is Line to the lock. Try unplugging the lock connector at the board and checking for continuity between 2 and 3 in the harness connector with the lid closed. The lock mechanism is a high failure part. -
IGB joined the community
candpappliance posted a topic in Appliance Service Manual Requests Forum
Manufacturer: LG Type of Appliance: Steam Closet Model Number: S3MFBN Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES Per home owner control works but unit wont work. Don't know the exact problem, I need the service manual to figure out this unit. Haven't worked on one, just like to be prepared with diagnostic and wiring schematic. Thank you. -
ColdElectron joined the community
- Yesterday
Manufacturer: Thermadore Type of Appliance: Freezer Model Number: T18ID900LP/11 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for a service manual for the model T18ID900LP/11 I don't know how to change the water valves on an Ice Maker.
jlmorrissr joined the community
Eric76692 joined the community
swapped out relay control board. N/C. the only wires I haven't viewed are the connects to the heating elements. any possibility it could be the sensor in the upper right corner of the oven ? 00425301
Catfish joined the community
Son of Samurai posted a blog entry in Appliance Repair Tech Tips
An interesting topic came up here in the Appliantology forums a little while back: The tech was working on an electric dryer that was DOA -- no lights, no response to button presses. He put his multimeter to the LoZ setting (as you should always do when making AC voltage measurements!), and he started checking for the power supply to the appliance at the terminal block. Here's what he got: L1 to N: 0 VAC L2 to N: 120 VAC L1 to L2: 20 VAC -- and while the meter leads are held on L1 and L2, the dryer UI lights up! Huh? What's going on here, both with the strange voltage reading from L1 to L2, and with the dryer coming to life while that voltage measurement is being taken? Let's crack out the schematic and find out. Here's the dryer schematic with the power supply to the board marked up. As you can see, the board's power supply is L1 and Neutral. There's no switch in either Line or Neutral going to the board -- the board is hardwired to its power supply. That, combined with the fact that, even when we measure at the terminal block, we get 0 VAC from L1 to Neutral, seems to indicate that we're missing L1, probably due to an open in the wall outlet or the house wiring. But how then is the board coming to life during our L1 to L2 voltage measurement? Well, let's look at what we're doing on the schematic when we perform that voltage measurement. How does connecting the meter like this cause the board to come to life? It's because we are connecting L2 to the L1 side of the circuit through the loading meter. Here's a simplified drawing of what's happening: We are effectively creating a series circuit with the loading meter and the control board. This also explains the weird voltage reading we got measuring from L1 to L2 -- that's how much voltage was being dropped across the loading meter. This is what that circuit looks like, drawn out as a line diagram. So there you have it -- a weird problem with whacky symptoms that turns out to have a simple solution! All of this came from a missing L1 at the wall outlet, the kind of thing you can easily catch by taking a measurement right at the outlet with a loading meter. Want to get in on the action? Join the Brotherhood of Techs at Appliantology. Appliantology.org is a cultivated, private community of techs. Get solid tech advice from working, professional techs and business owners. Avoid the endless noise and guesswork thrown at you from groups on social media. Download the service manuals, tech sheets, and service bulletins you need to git 'er done. Join the Brethren in the Craft right now with our membership options at Appliantology and see how it can help you in your business starting today. -
GE PFE28PELDDS Service Man Request
CullenG0 replied to CullenG0's topic in Appliance Service Manual Requests Forum
Most appreciative Sir - Thank you! -
FULL Service Manual Needed
Kvberry13 replied to CGA's topic in Appliance Service Manual Requests Forum
Encompass has the manual now. Posted in English. -
K0SE500ESS20 Kitchenaid Wall Oven Service Manual Needed
Captain Dunsel replied to David1's topic in Appliance Service Manual Requests Forum
Here you go: -
Captain Dunsel replied to CullenG0's topic in Appliance Service Manual Requests Forum
Uses the same mini manual as this model: -
CullenG0 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: GE Type of Appliance: Refrigerator Model Number: PFE28PELDDS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Respectfully request this manual if anyone has it. Thank you in advance. -
David1 replied to David1's topic in Appliance Service Manual Requests Forum
@Captain DunselSorry yes thats the one but I need SM, not tech sheet -
Model number is wrong! Could it be KOSE500ESS02? If so it uses this tech sheet! -
David1 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: KitchenAid Type of Appliance: Wall Oven Model Number: K0SE500ESS20 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES K0SE500ESS20 Kitchenaid Wall Oven Service Manual Needed please -
Looks like you can use this one:- 1 reply
- 2
I'm looking for the service manual
Son of Samurai replied to Rmeinholz's topic in Appliance Service Manual Requests Forum
Uses this manual: -
Range hood tech sheet
Son of Samurai replied to N1kon01's topic in Appliance Service Manual Requests Forum
Thanks, Cap! -
New Appliance Service Manual added: Whirlpool WVW51UC0FS3 Vent Hood Technical Manual
Whirlpool WVW51UC0FS3 Vent Hood Technical Manual View File Pub W10403806 - Rev B Submitter Captain Dunsel Submitted 05/20/2025 Category Appliance Repair Manual Pot Luck Supper
Blog Entries
Topics
