Upcoming Events
Where: Online via Zoom
- Past hour
Been researching this type of pressure switch far and wide and came up empty. (I bought another pressure switch from Bosch just in case- different design, with a factory-set adjustment screw under the housing which is held on with 3 tabs.) I'm going to try to make the tube longer. The nipple on the pressure sensor measures about 7/32" (.217"-.218") so that tells me 3/16" ID tubing will work with a 3/16" barbed connector. Just trying to figure out where do I put the slop so it doesn't chafe or get in the way. The original tubing is this black rubber star-shaped tubing, but I will extend (and not alter) with standard vinyl tubing. -
Mezan joined the community
- Today
Brian appliance SJ joined the community
Service Manuel Request
Thank you Captain -
Greg_S joined the community
GE Washer Personality Program Procedure WH22X32817 Part Install Instructions View File Pub 99-3000259 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
New Appliance Service Manual added: GE Part Instructions Wi-Fi Module Kit WH22X33297
GE Part Instructions Wi-Fi Module Kit WH22X33297 View File Pub 99-3000273 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper -
GE Washer Personality Program Procedure WH22X37219 Part Install Instructions View File Pub 99‐3000379 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
GE Washer Personality Program Procedure WH22X38440 Part Install Instructions View File Pub 99‐3000379 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
GE Washer Personality Program Procedure WH22X38517 Part Install Instructions View File Pub 99-3000297 Rev 1 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
GE Washer Personality Program Procedure WH22X38558 Part Install Instructions View File Pub 99-3000406 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
Chauncey1 joined the community
prince23solomon joined the community
- Yesterday
lou123 started following LG DLGX2502V Dryer Keeps Tripping Thermal Limiter Fuse
lou123 posted a topic in DIY Appliance Repair Help
I have an LG DLGX2502V dryer that just started tripping thermal fuse. I disassembled the exhaust duct work and cleaned it, though it was not very bad at all. I reassembled and ran it on air dry just to check exhaust flow, good exhaust at outside vent baffle. Still no heat, found the thermal limit fuse, was able to reset it and it ran, gas came on, and it seemed to be heating up fine. Shut it off, later on added wet clothes and ran it. Limit switch tripped again. Bad limit switch? What should I check. Thanks in advance. -
Captain Dunsel started following Service Manuel Request
Captain Dunsel replied to Rich Armstrong's topic in Appliance Service Manual Requests Forum
This should work: -
Rich Armstrong started following Service Manuel Request
Manufacturer: Kenmore/LG Type of Appliance: Top load Washer Model Number: 79631512210 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Low water fill
shxm78 joined the community
Huebsch DR5102WE ZDE6HRYS177CW01 dryer service manual request
Captain Dunsel started following Huebsch DR5102WE ZDE6HRYS177CW01 dryer service manual request
Try this one: -
Centre St-Exupery started following Huebsch DR5102WE ZDE6HRYS177CW01 dryer service manual request
Manufacturer: Huebsch Type of Appliance: Dryer Model Number: DR5102WE ZDE6HRYS177CW01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Huebsch DR5102WE ZDE6HRYS177CW01 dryer service manual request Thank you -
frustrated dude joined the community
Captain Dunsel started following GE Washer Personality Program Procedure WH22X32817 Part Install Instructions
Whirlpool WTW4816FW3 washer sounds like a jet engine
Appliance Fixer 68 replied to Appliance Fixer 68's topic in DIY Appliance Repair Help
I have a newer Whirlpool washer, model WTW4816FW3, that is very loud on the spin cycle and sounds like a jet taking off. It’s not banging and it’s not extremely off balance but when the spin cycle is very loud. No other issues, it’s just loud on the spin cycle. I purchased this machine in 2023. Every time I do laundry it’s very loud on the spin cycle. -
Temp joined the community
Craigp602 joined the community
Appliance Fixer 68 posted a topic in DIY Appliance Repair Help
My fairly new Whirlpool WTW4816FW3 washer that I bought new in 2023 has became very loud on the spin cycle - sounds like a jet engine. Any ideas on what this can be? When it spins it’s extremely loud and sounds like a jet is taking off in the house. Still seems to run fine otherwise, just very loud. Washer is only a year old so can I get a warranty? I didn’t buy extended warranty. -
Follow up question to old Kenmore Refrigerator water inlet valve
lrubin28 posted a topic in DIY Appliance Repair Help
Kenmore Refrigerator model 10659212990. Water inlet valve 2206123. I bought a replacement water inlet valve 2206123. ...it's a triple solenoid model for a kenmore 10659212990. The incoming water supply goes to the brass nut - easy. But that's where I get confused. There's another solenoid (green) with a 1/4" port. I think this would go to the ice maker, and that's a 1/4" line that I can see running up the back of the fridge. So if I'm right, that knocks out 2 of the 5. So now I have 3 open ports on the 2206123 and they all appear to be 5/16". Coming from the fridge, there are 3 tubing lines bundled together before disappearing inside the fridge. 2 of them are 5/16" and the other is 1/4". How do I identify which tube goes into which port of the valve? (Unfortunately there are no documents on back of fridge or under front grate). It's an old fridge and no one seems to have any info on it. I'd appreciate it greatly if someone could help me out. Do I need to take the fridge apart to see where each of the 3 lines go? Hopefully not...thank you in advance... -
Whirlpool front-loading automatic washer W10175588C not spinning up to full speed during spin cycle
MrApplianceMatt replied to bernk's topic in DIY Appliance Repair Help
It sounds like a few things might be going on but it's hard to tell from this video. The drain pump sounds loud so I would investigate that for a blockage or restriction. Check for any play between the spin basket and the tub as that would indicate a bearing or basket support arm failure. Pull the back panel off and look for signs of leakage from the basket drive shaft. There should be some technical information tucked under the top somewhere. I would look for error codes to see what the control board thinks is wrong and why it's limiting spin speed. -
Whirlpool WTW5000DW0 bearing repair?
MrApplianceMatt replied to Appliance Repair 60's topic in DIY Appliance Repair Help
This would require a gear box replacement. The gear box is self contained and is not designed to be rebuilt. It includes the tub seal. Is there any lateral play between the tub and the basket? If so, then this would require replacing the basket as well. These machines were designed for economy, not longevity.
Blog Entries
Topics
Captain Dunsel · Started
