  2. Manufacturer: LG Type of Appliance: DRYER Model Number: DLE3400W Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hi all, I know this has been topic beaten to death, but I’ll through a few more blows.I watched the workshop on this flow sense but this one is different as they show no “Flow Sense”on the wiring diagram. Ran the install test with vent connected and disconnected. Failed both. Inspected blower assembly and all is clear, drum turns easy. Lint screen passes water. I’m assuming they use a temperature to determine blockage. Question is, is it the sensor on blower housing? Or is it a difference between two sensors? The manual only talks about clogged venting, never really shares any info on sensors. LG says you can turn this off. Timed dry & wrinkle care. It should show on or off. Mine showed 1 or 0, which digitally could be on or off. Appreciate any tips.
  3. Uses this mini manual: You should be able to use this service manual:
  4. Today
  5. Manufacturer: GE Type of Appliance: 48 Inch Refrigerator Model Number: psb48ysnhss Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes hey guys this is a fairly new unit. 48inch GE Profile. I need a service manual please.
  6. Uses the same one as this model:
  7. Manufacturer: GE Type of Appliance: Refrigerator Model Number: PYE22KBLCTS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Customer is getting condensation on the left side refrigerator wall inside fridge. I’m looking for the tech sheet to see if there is supposed to be a heater for the IM air duct or if it is bad insulation inside the wall. Thanks!
  8. Those service manuals are published the year the model family came out. I don't know of any definitive way to find them. I googled the part# and found this:
  9. Manufacturer: Electrolux / frigidaire ? Type of Appliance: refrigerator Model Number: GRSC2352AF0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Could only find tech sheet download for it from a different model # but I believe the tech sheet offered in the download section will work for this model # , what I really need is the service repair manual if there is one. The main control board underneath the front of this model is a little different than the normal ones you can just take out easily. . Trying to find out the removal process for the main board located behind the refrigerators lower kick plate ??
  10. Uses the schematic and error codes doc from this bundle:
  11. Bosch SHEM78WH5N/32 Dishwasher Service Manual View File PUB 58300000183868 Submitter Son of Samurai Submitted 06/04/2025 Category Appliance Repair Manual Pot Luck Supper
  12. Version 1.0.0
    1 download
    PUB 58300000183868
  13. Uses this manual: And the schematic in this bundle:
  14. Here you go:
  15. Sub-Zero UW-24 Wine Cooler Service Manual View File PUB 7040748 Rev A September 2016 Submitter Son of Samurai Submitted 06/04/2025 Category Appliance Repair Manual Pot Luck Supper
  16. Version 1.0.0
    0 downloads
  17. Uses this manual:
  18. Yesterday
  19. Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHEM78WH5N/32 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Unit randomly throws E05 Error at the end of the cycle, cannot duplicate customer says that it will happen at the end. Checked water pressure from main water supply, checked valve filter for any debris. Checked water level and all good. Anyone ran into this error reset the main board and will put on test.
  20. General Appliance
    RF27T5501SR. Need manual
    Disregard. This does work. The section was hidden in the middle. Thank you!
  21. General Appliance
    Thanks buts That's not it. It's a new one with a Giant touch screen panel. Looks like service mode needs to be done from the hub.
  22. Captain Dunsel
    This should work: This service bulletin:
  23. Manufacturer: Samsung Type of Appliance: Refrigerator Model Number: RF27T5501SR Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Please need manual ASAP
  24. General Appliance
    need service manual for Samsung refrigerator
    I need this manual too. Nothing yet?
  25. Thank you
  26. Here you go: This mini manual:
  27. I think you should do a test on a Front load washer dispenser hose especially tight area under the spring cross bar see pics I broke the nipple trying to get the clamp to move. clamp is under the crossbar just above the tub obviously serious pain
  28. Manufacturer: GE Type of Appliance: Washer Model Number: Gfw550ssn5ww Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I am in search of a service manual for a GE Gfw550ssn5ww front load washer. Thank you
