Upcoming Events
12 July 2025 02:00 PM Until 03:00 PM
Where: Online via Zoom
- Today
Bosch dishwasher service manual needed SHE53B75UC
FortRepairs posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHE53B75UC Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I need a service manual for this dishwasher, I found a similar model number in the forum but it was for a 2013 model and this is a 2024. The posted manual does not pertain to this dishwasher. Right now I'm getting a water inlet valve icon but the water inlet valve is working I'm suspecting there's a problem with the flow meter but I need the service manual to further diagnose -
Ethan Leyt started following LG Washer/Dryer combo - WKHC202HBA
Ethan Leyt posted a topic in Appliance Service Manual Requests Forum
Manufacturer: LG Type of Appliance: Washer/dryer combo Model Number: WKHC202HBA Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Tes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hi, I'm looking for the service manual and disassembly instructions for this model, if available. Thanks -
Pro-Tech7893 started following Needing tech manual for LSDL6336F/00
Pro-Tech7893 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: LG Type of Appliance: Gas Range Electric Oven Model Number: LSDL6336F/00 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Needing tech manual for LSDL6336F/00 -
Son of Samurai started following Need service manual WGD5000DW2
Son of Samurai replied to drew 83's topic in Appliance Service Manual Requests Forum
Thanks, Cap! -
New Appliance Service Manual added: Whirlpool WGD5000DW2 Dryer Wiring Sheet
Whirlpool WGD5000DW2 Dryer Wiring Sheet View File Pub Wiring Sheet - W10185994 - Rev M Submitter Captain Dunsel Submitted 07/07/2025 Category Appliance Repair Manual Pot Luck Supper -
JustinTT joined the community
LeTournevis joined the community
Captain Dunsel started following Service manual for Frigidaire FGHB2844LF3
Captain Dunsel replied to Emperorappliance's topic in Appliance Service Manual Requests Forum
Uses the same tech sheet as this model: This comes up on the Electrolux site: Also this one: Also this one:- 1 reply
- 1
appleimac started following GE Potscrubber 940 - repairman caused leak thru permatuf bottom thru heating element area
appleimac posted a topic in DIY Appliance Repair Help
Repairman had trouble getting heating element off old GE Potscrubber 940 dishwasher - I believe he had to cut heating element off, connector was different on the replacement one if I remember correct. When he was done, he had to patch a hole in the permatuf bottom, well, it has started to leak. The repairman is going to text me the name of the stuff he used, but I am wondering if there is a better product to use, or suggestions. I assume replacing the permatuf bottom would be tough, unless I could find an old donor machine, and not sure how difficult the job would be. When I removed the bottom panel and watched it run, water was dripping off the plastic cover over the heating element connectors - unto the metal box housing the power connection, so the GFI has been tripping when this area gets wet enough. Circuit breaker has not been tripping. I took some pics, looks like area that needs sealing is simply around where the heating element goes into the permatuf bottom, right now he has some grey stuff applied around the circular opens. I was considering using Sugru moldable glue, which is supposed to be dishwasher safe, good for 356 degrees, or something like that - shockproof - or is there something better for this type of repair? -
Emperorappliance posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Frigidaire Type of Appliance: Refrigerator Model Number: FGHB2844LF3 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Looking for the service manual for this model. I have never seen an ice maker like this before but I have multiple issues with this unit and am looking for an any service manual to assist in this job. Thanks! - Yesterday
rack14650 joined the community
crisboyblue joined the community
Electrolux FG EI27BS16JS6 SM Request
Captain Dunsel replied to JSMequipmentservices's topic in Appliance Service Manual Requests Forum
Uses the same wiring diagram as this model: The May have some similarities to Parts of this manual:- 1 reply
- 1
ralvarelugones joined the community
Uploading wiring diagram and waiting on approval: -
Here you go:- 1 reply
- 1
Manufacturer: Empava Type of Appliance: Cooktop Model Number: EMPV-36GC23 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual for EMPV-36GC23, if possible
ecappliancecompany posted a topic in Appliance Service Manual Requests Forum
Manufacturer: kenmore Type of Appliance: refrigerator Model Number: 111.75035120 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes tech sheet needed -
Manufacturer: Electrolux Type of Appliance: Refrigerator Model Number: EI27BS16JS6 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes -
Manufacturer: Whirlpool Type of Appliance: Dryer Model Number: WGD5000DW2 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual for WGD5000DW2, Thanks!
Son of Samurai commented on Son of Samurai's event in Tech Training
Appliantology Live Dojo, Saturday, 6/28/2025 @10 AM ET
until
Some great discussions in this one! Here are the recordings from this workshop. -
Frank Bartonek joined the community
GE ZTDX1FPSN1SS oven SM and Assembly Instructions Request
Son of Samurai replied to JSMequipmentservices's topic in Appliance Service Manual Requests Forum
Uses this service guide:- 1 reply
- 1
Wayne bushey joined the community
Service Manuel Request
Captain Dunsel replied to Rich Armstrong's topic in Appliance Service Manual Requests Forum
Try this one:- 1 reply
- 1
BNeal joined the community
Manufacturer: LG Type of Appliance: Top Load Washing Machine Model Number: WT7405CW/00 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I need to remove the tub Captain.There might be more number at the end of the model number. Thanks Cap!
need a wiring diagram please
BigMix replied to BigMix's topic in Appliance Service Manual Requests Forum
thanks a lot -
Captain Dunsel replied to BigMix's topic in Appliance Service Manual Requests Forum
Seems to be too old to pull up a wiring diagram. Tech sheet was 941869 though! -
Manufacturer: kenmore Type of Appliance: freezer Model Number: 1068332070 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Need a wiring diagram, thanks in advance
mhatcher joined the community
Looking for Mentorship and/or Shadowing Opportunity in Dallas, TX
Shaphan Hawks replied to Ryan Repairs's topic in Looking for a Job
Im in Albuquerque. Come by anytime
Blog Entries
By Rhubarb Tau in Rhubarb Tau's Sloggy Vlog Blog Bog4 comments
2 comments
Topics
Captain Dunsel · Started
until
