Upcoming Events
Where: Online via Zoom
- Yesterday
Thank you! -
It took a good bit of time to identify that thread, but I eventually found it to be an "electrical panel" thread; not a regular M10 "standard, fine, or extra fine" thread. From what I understand, many appliances need relatively thin nuts to fit into tight spaces and need VERY fine threads to hold securely without requiring a much thicker nut to have room for enough threads for the required holding power. That's why in my initial testing even standard M10 "extra fine" nuts were too coarse for that thermostat. Those threads are specified by a adding a specific thread pitch in mm. Besides their use in electrical panels, appliances, lamps, etc., such thread pitches are also commonly used in panels on cars and trucks. That particular thermostat's threaded area is an M10 x 0.75mm thread. (M10 "extra fine" thread is only M10 x 1.0mm). I bought a small bag of M10 x 0.75, steel, metric hex nuts that are thin (only 2.6mm high) on Amazon. They screwed right on to the thermostat's threads with no issues. A 60-count bag was only $7.89. (There are other offerings for them, but I bought the first one I saw that I could next-day Prime in). Just bring up Amazon and type the ASIN (Amazon Stock ID Number) "B0CN2JNVXF" into the search box and click the Search symbol. (Or, if you'd rather search by spec than ASIN, the listing for the bag I bought had the listing title: "PATIKIL M10x0.75 Steel Hex Nuts, 60 Pack Metric Thread Zinc Plated Finished Hardware Nuts Screw Bolt Fasteners for Lamps Machinery Repair 2.6mm Height"). I've been working higher priority projects and haven't yet had time to go back to the chest freezer repair, but this should allow me to mechanically attach a mount to the 10085. -
old_manchu_warrior joined the community
SpicyPoke joined the community
citizenX replied to appleimac's topic in DIY Appliance Repair Help
Glad you got it going. Surprised you were still able to find a timer. Good for another 3000 miles! -
AngieDo joined the community
Pull off the spray arm, take out screw and remove filter ring. Pull sump cover and clean it out. Check ball inside, clean it as well. If not clear to you, look up exploded view or service manual. This dishwasher does not have a drain pump. The main pump does the draining when the drain valve solenoid is activated. -
georgiapossum joined the community
oneclickpolitics joined the community
Vance R started following Lg dishwasher
- Last week
Centre St-Exupery started following Fisher & Paykel DD24DCTX6 dishwasher service manual request
angelo19 joined the community
sailingSD joined the community
Carope joined the community
Still nothing at LG web site for this refrigerator. -
talquin67 joined the community
smdsteve joined the community
Hi there! Anyone know what could be causing a dishwasher not to drain completely? I mean the pump is obviously working because it does drain about 85% of the water, but every time it finishes there is a small puddle of water. The filter is 100% clean and inside the dishwasher itself, all drain hoses are clean and clear, garbage disposal is also clean and clear. Took drain pump out and nothing was caught up inside of it or anything. Bad board? Bad drain pump? GE dishwasher model number: GSD3300K00BB Serial number: DL873297B
Service Manuel Request
Thank you Captain -
Centre St-Exupery replied to Gino778's topic in Appliance Service Manual Requests Forum
Can I squeeze in here to insert mine, since Im looking for the same? Serial number 201MRRH2D902 -
Kenmore Washer 110.2022251 tech sheets needed
Mark A replied to Mark A's topic in Appliance Service Manual Requests Forum
Thank you. -
Captain Dunsel replied to Mark A's topic in Appliance Service Manual Requests Forum
Thermador HMCN36FS Hood Service Manual Request
Manufacturer: Thermador Type of Appliance: Hood Model Number: HMCN36FS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need the service manual and wiring diagram for Thermador Hood model HMCN36FS -
Mark A posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Kenmore Type of Appliance: Washer Model Number: 110.2022251 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need the tech sheets for Kenmore washer 110.2022251. Thank you. -
LG Refrigerator LRMWS2906 - Water dispenser light stopped working
sbi123 posted a topic in DIY Appliance Repair Help
Greetings, As the subject says: Light should come on when the water dispenser is used. Same light can be turned ON permanently with a LIGHT button on the panel. The light does not come on, either when pressing the water dispenser or the LIGHT button. The panel works fine, all lights come on, it is just the dispenser light. The dispenser in this fridge is super slim. Any idea how to approach this? Does anyone happen to have the service manual and is able to share? Thanks. -
Manufacturer: Lg Type of Appliance: Dishwasher Model Number: Ldfc2423v Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for service manual
Whirlpool Refrigerator Model# ET18GKXFW0 1 Need schematics and user manual
Excellent. Thank you. -
Manufacturer: Whirlpool Type of Appliance: Refrigerator Model Number: ET18GKXFW0 1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need the tech sheets (schematic, user manual, etc.) for this Whirlpool Refrigerator Model# ET18GKXFW0 1. The light comes on when the door is open, but no freezing, no cooling. Thanks for your help.
Mark A changed their profile photo
Whirlpool electric dryer WED4720RW0 tech sheet
Captain Dunsel replied to Freddy B's topic in Appliance Service Manual Requests Forum
Uploading tech sheet, service manual and waiting on approval: -
Freddy B posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Whirlpool Type of Appliance: Electric dryer Model Number: WED4720RW0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for the tech sheet for whirlpool electric dryer model # WED4720RW0. lightning strike has caused it to not work, the interface and all functions have seized. Believe it’s the board. -
Fisher Paykel DD24DCTX7 Dishwasher service manual request
You should be able to use this:- 1 reply
- 1
Blog Entries
2 comments
Topics
