Upcoming Events
07 June 2025 02:00 PM Until 03:00 PM
1All are invited to join in the conversation for all things Appliantological: bidness, customers, tools, troubleshooting, flavorite brewski, whatever. Webcams and microphones are open and live!
Where: Online via Zoom
- Past hour
Jeffrey.Z joined the community
- Today
Update on this - Repair Clinic now lists only 1 motor/pump for this model, from what I have been told this should not be the problem. Recently I was told they used one pump/motor for models prev to 1988, and a different one after that. My DW should be in the later group, I think built around 1980. I was told it sounds like a faulty timer - I looked at the number it was supposed to do on Repair Clinic, they don't have it - found it new on ebay - same model number as Repair Clinic had listed as, the 672 - I noticed that I couldn't get that previously at RC, so that order had been cancelled, and the timer I had bought of ebay shows as numbers WD21X626, WD21X0626,271598. Were these 3 latter model numbers NOT compatible with the GSD940-L-02? Is that why the water pumps out, then the motor continues to run during the drying cycle? -
Manufacturer: Whirlpool Type of Appliance: Dishwasher Model Number: Wdf331pahs1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I
Whirlpool refrigerator bottom freezer (Model GB2FHDXWB02) fridge warm freezer cold
LivBriggs replied to matty1stop's topic in DIY Appliance Repair Help
Given the age of your Whirlpool (14 years), it's right on the edge of what’s worth throwing parts at. If the freezer’s cold but the fridge is warm, it’s likely an airflow issue—either a failed evaporator fan, blocked vent, or defrost system problem (frost buildup blocking air to the fridge). The defrost thermostat and wiring harness (WPW10290745) could be the culprit, but at $65–$200, you’re gambling on a maybe. Before spending that, check if the evaporator fan is running and make sure there’s no ice buildup blocking vents. If the fan’s dead or there's frost, it might be worth replacing the part—but only if you're comfortable with DIY. Otherwise, you’re better off putting that money toward a new unit. -
Looking for tech sheet for GE refrigerator model number PYE22KBLCTS
AldoG replied to AldoG's topic in Appliance Service Manual Requests Forum
Thanks! - Yesterday
bobthebuilder22039 joined the community
Loengrin Montilla joined the community
DLE3400W flow sense issue.
S & E Appliance replied to S & E Appliance's topic in Appliance Service Manual Requests Forum
Posted in wrong forum, sorry about that -
extrapolater1 joined the community
Koi Guy commented on Son of Samurai's event in Tech Training
Captain Dunsel started following Need service manual
Need service manual
Here you go: Uses this mini manual: -
Vjbarbarita joined the community
drew 83 started following Need service manual
Manufacturer: GE Type of Appliance: Washer Model Number: GFW650SPN2SN Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual for GFW650SPN2SN Thanks!
PLANE joined the community
big bad bob joined the community
DarkHorse96 joined the community
S & E Appliance posted a topic in Appliance Service Manual Requests Forum
Manufacturer: LG Type of Appliance: DRYER Model Number: DLE3400W Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hi all, I know this has been topic beaten to death, but I’ll through a few more blows.I watched the workshop on this flow sense but this one is different as they show no “Flow Sense”on the wiring diagram. Ran the install test with vent connected and disconnected. Failed both. Inspected blower assembly and all is clear, drum turns easy. Lint screen passes water. I’m assuming they use a temperature to determine blockage. Question is, is it the sensor on blower housing? Or is it a difference between two sensors? The manual only talks about clogged venting, never really shares any info on sensors. LG says you can turn this off. Timed dry & wrinkle care. It should show on or off. Mine showed 1 or 0, which digitally could be on or off. Appreciate any tips. -
Porterfix joined the community
Captain Dunsel started following Need Service Manual for GE 48 INCH Profile psb48ysnhss
Captain Dunsel replied to General Appliance's topic in Appliance Service Manual Requests Forum
Uses this mini manual: You should be able to use this service manual: -
General Appliance started following Need Service Manual for GE 48 INCH Profile psb48ysnhss
General Appliance posted a topic in Appliance Service Manual Requests Forum
Manufacturer: GE Type of Appliance: 48 Inch Refrigerator Model Number: psb48ysnhss Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes hey guys this is a fairly new unit. 48inch GE Profile. I need a service manual please. -
Captain Dunsel replied to AldoG's topic in Appliance Service Manual Requests Forum
Manufacturer: GE Type of Appliance: Refrigerator Model Number: PYE22KBLCTS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Customer is getting condensation on the left side refrigerator wall inside fridge. I’m looking for the tech sheet to see if there is supposed to be a heater for the IM air duct or if it is bad insulation inside the wall. Thanks!
need service repair manual not tech sheet
vee8power replied to darren412's topic in Appliance Service Manual Requests Forum
Those service manuals are published the year the model family came out. I don't know of any definitive way to find them. I googled the part# and found this: -
darren412 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Electrolux / frigidaire ? Type of Appliance: refrigerator Model Number: GRSC2352AF0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Could only find tech sheet download for it from a different model # but I believe the tech sheet offered in the download section will work for this model # , what I really need is the service repair manual if there is one. The main control board underneath the front of this model is a little different than the normal ones you can just take out easily. . Trying to find out the removal process for the main board located behind the refrigerators lower kick plate ?? -
Son of Samurai replied to candpappliance's topic in Appliance Service Manual Requests Forum
Uses the schematic and error codes doc from this bundle: -
New Appliance Service Manual added: Bosch SHEM78WH5N/32 Dishwasher Service Manual
Bosch SHEM78WH5N/32 Dishwasher Service Manual View File PUB 58300000183868 Submitter Son of Samurai Submitted 06/04/2025 Category Appliance Repair Manual Pot Luck Supper -
Manual Needed for SHE878WD5N/01 or a manual that's compatible
Son of Samurai replied to McLoughlin132's topic in Appliance Service Manual Requests Forum
Uses this manual: And the schematic in this bundle: -
Need tech sheet for Sub Zero UW-24/S/PH-RH
Son of Samurai replied to DStenoien's topic in Appliance Service Manual Requests Forum
Here you go: -
New Appliance Service Manual added: Sub-Zero UW-24 Wine Cooler Service Manual
Sub-Zero UW-24 Wine Cooler Service Manual View File PUB 7040748 Rev A September 2016 Submitter Son of Samurai Submitted 06/04/2025 Category Appliance Repair Manual Pot Luck Supper -
Service manual request WAT28400UC/14
Son of Samurai replied to drew 83's topic in Appliance Service Manual Requests Forum
Uses this manual: - Last week
candpappliance posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHEM78WH5N/32 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Unit randomly throws E05 Error at the end of the cycle, cannot duplicate customer says that it will happen at the end. Checked water pressure from main water supply, checked valve filter for any debris. Checked water level and all good. Anyone ran into this error reset the main board and will put on test. -
RF27T5501SR. Need manual
General Appliance replied to General Appliance's topic in Appliance Service Manual Requests Forum
Disregard. This does work. The section was hidden in the middle. Thank you!
Blog Entries
2 comments
Topics
matty1stop · Started
until
