  2. Today
  3. Manufacturer: Frigidaire Type of Appliance: Front load washer Model Number: Ltf2140fs1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual
  4. Thank you, so it said that the ER code is a switch failure. Would that be in the keypad that I'm looking for. Thanks again. I'm new to this and there are so many different models.
  5. Uses the same tech sheet as this model: May have some similarities to Parts of this manual:
  6. Manufacturer: Kenmore Type of Appliance: Washer Model Number: 41748102701 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need the tech sheet for this washer so I can get it in diagnostic mode and tear it down to work on it. Thanks. washer does nothing at the moment. UI works but nothing else.
  7. Hi Brian. Just wanted to give an update. I replaced the belt (it had already snapped) and the dryer is working as it should. Very simple procedure putting in the new belt. Glad that's all it was. I actually had more trouble putting the front panel back in those little hooks and aligning the drum to the door at the same time. Thanks again for all the help! Truly appreciated! ps. And yes, I didn't forget to clean up inside the dryer.
  8. Found a ton of videos on you tube it was simple sorry don't have a link.
  9. in the same time there is another trouble regarding The Wide open CoolSelect Pantry , where the three lights still flashing continuously.
  10. @DarkHorse96 Don't try it - you will never get them back together correctly. After you get the new one mounted by making a mounting bracket like I suggested and you know all is working OK - then try to take the old t-stat apart and see what you end up with.
  11. I know I’m late to this party, but just late night scrolling and came across this topic and wow! Has a service bulletin been released about this? Our local supplier here says the boards for these is the number two selling part in their warehouse, I’ve replaced two boards in the last two weeks on two different machines, now the gears are turning in my head because they were only four year old machines with very strange behavior. Haven’t heard back from either customer, only time will tell…
  12. Yesterday
  13. Captain Dunsel
    FGHD2465NF1A tech sheet
    @fcm350 Tech sheet is also in the same download as the parts list!
  14. Captain Dunsel
  15. Manufacturer: Fridgadare Type of Appliance: Dishwasher Model Number: FGHD2465NF1A Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Looking for tech manual to put the dishwasher in diagnostic mode. I found one on the parts but not how to put it into diagnostic mode. Customer said the error code was ER. Thanks for your help.
  16. fcm350
    Service manual
    Thank you.
  17. Asko
  18. Captain Dunsel
    Frigidiare Ref mod: FGUS2642LF2
    Try this also:
  19. Captain Dunsel
    This doesn't come up for your model but try this.Frigidaire is horrible for service manual.
  20. Techonamission
    can you provide the Service manual too please? This tech sheet doesnt have error codes
  21. Captain Dunsel
  22. Manufacturer: Frigidaire Type of Appliance: Refrigerator Model Number: FGUS2642LF2 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Requesting tech sheet for Frigidiaire ref mod: FGUS2642LF2
  23. Good question how does it come apart?
  24. Hi everybody, since few months , my ice dispenser including the whole display is not working , when i tried to reach Samsung suppart , they suggest to replace the Assy cover dispenser , but when i received finaly , i have replaced , but nothing happened. did anyone experienced the same issue , can someone help please ? i'm suspecting a voltage or current missing to supply this Front board (ice+water dispenser + Display). thanks in advance. PS : fresh water still working , and there is ice cubes in the container inside the fridge.
  25. What is a hestan pan?
  26. Thanks! That sounds like a viable alternative if I can't figure out how to use the actual mount off the original 10085. I did notice that there seems to be some kind of bend-over / crimp tag on the bottom 2 corners of both the original thermostat and the substitute. Has anyone tried to bend those tabs of a dead one to verify whether we could theoretically release both stats' mounts and securely attach the original mount to the 10085? Of course, I'd also be betting that the 10085's exterior mount will pull off an unseen underlying shaft because that big threaded region its shaft may be too long to fit under the old mount.
  27. Manufacturer: Asko Type of Appliance: Dryer Model Number: T411VDWU Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for service manual, thanks! T411VDWU
