Upcoming Events
- Past hour
LG Combo Washer/Dryer WM6998HBA Service Manual & Parts Diagram Needed
FLAppliances replied to FLAppliances's topic in Appliance Service Manual Requests Forum
Thanks Vance! You’re the man! - Today
Duane_NEPA joined the community
Son of Samurai started following LG Combo Washer/Dryer WM6998HBA Service Manual & Parts Diagram Needed and Need a techmanual for new LG Washer
Son of Samurai replied to Wayne Moore's topic in Appliance Service Manual Requests Forum
Thanks, Vance! Approved. -
New Appliance Service Manual added: LG WT8480CL Washer Service Manual
Vance R posted a topic in Appliance Service Manual Requests Forum
LG WT8480CL Washer Service Manual View File PUB MFL69647043 Submitter Vance R Submitted 06/08/2025 Category Appliance Repair Manual Pot Luck Supper -
Son of Samurai replied to FLAppliances's topic in Appliance Service Manual Requests Forum
LG WM6998HBA Washer Dryer Combo Service Manual View File PUB MFL71873719 Submitter Vance R Submitted 06/08/2025 Category Appliance Repair Manual Pot Luck Supper
twang1010 joined the community
Captain Dunsel started following Service manual
- 1 reply
- 1
Budget Appliance Repair replied to qkcam's topic in DIY Appliance Repair Help
Wouldn't be hard to make a mount - just use a strip of plumbers strapping cut to the correct length, make "L" bends at each end so enough of the knob shaft will stick through the mounting hole, find a nut the correct size of the center threaded mount. Drill small enough holes for the two mounting bolts/screws will thread into the plumbers strap or use speed clip nuts if the holes that are in the plumbers strapping is too big and already at the correct mounting screw spacing. -
xeudoxus joined the community
tmoss05 joined the community
Captain Dunsel started following LG Fridge LRFNS2200S/01 SM Request
Captain Dunsel replied to JSMequipmentservices's topic in Appliance Service Manual Requests Forum
@JSMequipmentservices I wonder if this one is close enough? -
JakeSnell joined the community
- Yesterday
Vance R replied to JSMequipmentservices's topic in Appliance Service Manual Requests Forum
Still nothing pulls up at LG. Most likely because it is Canadian model. -
Vance R replied to Wayne Moore's topic in Appliance Service Manual Requests Forum
Uploaded service manual pending approval. -
Vance R replied to FLAppliances's topic in Appliance Service Manual Requests Forum
Uploaded service manual pending approval. For parts best to try Encompass parts. -
Vance R posted a file in Appliance Repair Manual Pot Luck Supper
marky joined the community
jimbaker joined the community
Yev28 joined the community
Alexei73 joined the community
Manufacturer: Bosch Type of Appliance: Dryer Model Number: WTVC6330US/11 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Looking for tech manual, couldn't find any. Thanks
I've also been hunting for a substitute for the GE WR09X10053 part# GE says is the correct replacement for my FCM5DMCWH. I had little or no luck other than what looked to be discolored, very used-looking parts on eBay. After seeing QKCAM's post, I bought the Amazon WR50X10085. But when I attempted to install it, I hit a snag. The original thermostat on mine was screwed into the back of the temperature adjustment knob's mounting plate with two screws that went through 2 holes into plastic posts on the back of that plate. My problem is that the Amazon WR50X10085 has no mounting bracket at all. So the only thing holding a device that's controlling full amperage 120v power would be the friction press-fit of the shaft into the freezer's control knob. That doesn't seem safe to me. My freezer's original thermostat was labeled "CS6448N" and "WPF27S-103-032"). There was no significant number of visible threads on its shaft. So I didn't see any obvious way to get the stand-off mount with the screw holes off the original thermostat and onto the WR50X10085. The 10085's shaft is threaded. It looked like the tab the knob hits to turn the freezer off prevents the spinner from rotating 360 degrees to unscrew the plate from the original one (if it is threaded) or to re-screw the old mounting plate onto the 10085. Just to further confuse the issue, I've since located a supposed "New old stock" WR09X10053 online. for nearly $100. It's pictures show it does have what looks like a nearly identical mounting plate - but that plate has no screw holes at all. So apparently the mounting for that thermostat has changed between revisions / serial numbers of this "Compact 5" freezer. Does anyone have any ideas of how to move the mounting plage from the CS6448N to the WR50X1008? Thanks in advance. -
Untangle This Tricky Water Valve Problem with the Troubleshooting Ten-Step Tango
TSheff commented on Son of Samurai's blog entry in Appliance Repair Tech Tips
Great tutorial, thank you Sam - Last week
Blake30 commented on Son of Samurai's blog entry in Appliance Repair Tech Tips
Awesome breakdown enjoyed the article -
FLAppliances posted a topic in Appliance Service Manual Requests Forum
Manufacturer: LG Type of Appliance: Washer Dryer Combo Model Number: WM6998HBA Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hi ya’ll. Rolling the dice here but hoping someone can help with providing a service manual and parts diagram for this unit. I understand it’s newer so information is limited. I did find a link for this unit with a manual but did not correspond. This was confirmed with a visit to the customer’s and schematic is as follows. -
Thank you -
Frigidaire dishwasher Service Manual and/or tech sheet request
frunch replied to frunch's topic in Appliance Service Manual Requests Forum
Thank you! Have a nice weekend -
Captain Dunsel replied to frunch's topic in Appliance Service Manual Requests Forum
Uses the same tech sheet as this model: -
frunch posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Frigidaire Type of Appliance: Dishwasher Model Number: GDPP4517AF0A Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes May I please have the tech sheet or service manual for this unit, couldn’t find one using the usual searches. Thank you! -
Frigidaire service manual req
Son of Samurai replied to NoahB24's topic in Appliance Service Manual Requests Forum
Domo, Captain! -
New Appliance Service Manual added: Frigidaire FCFE2425AS Range Service Data Sheet and Parts List
Frigidaire FCFE2425AS Range Service Data Sheet and Parts List View File Pub Service Data Sheet 808532305 Pub Parts List 5995724373 Models: FCFE2425AS FCFE2425AW Submitter Captain Dunsel Submitted 06/06/2025 Category Appliance Repair Manual Pot Luck Supper
Blog Entries
2 comments
Topics
