Upcoming Events
12 July 2025 02:00 PM Until 03:00 PM
Where: Online via Zoom
- Past hour
craymer4 joined the community
- Today
woody2a joined the community
GE fridge freezer warm
Captain Dunsel replied to asteysn2's topic in Appliance Service Manual Requests Forum
You should be able to use this mini manual: May have some similarities to Parts of this manual:- 1 reply
- 1
asteysn2 started following GE fridge freezer warm
Manufacturer: GE Type of Appliance: ref Model Number: PFSS5NJWA Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Y Customer with GE frige says freezer is warm. Fans seem to be running but cannot verify Compressor. Anybody have a tech sheet or S,M?
- Yesterday
JDero started following Kenmore refrigerator 111.75035020 part discontinued
JDero replied to Paulie's topic in DIY Appliance Repair Help
Hey Paulie, by any chance did you give it a shot? I’m having the same issue with two different fans. -
JDero joined the community
CitywideApp joined the community
Bosch range E305 after bacon fire mod# HGIP056UC/07
tex77573 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Bosch Type of Appliance: Range Model Number: HGIP056UC/07 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): no Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes This mod# will not come up any where but the cust text me a pic and I feel sure it is right. Have not been out yet but apparently cust had a bacon fire and then E305. Thanks Boyd -
Manufacturer: Lg Type of Appliance: Wall oven Model Number: WDEP94230 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Y Looking for any tech data. Thanks
drkidd1 joined the community
Samsung RF29DB970012 service manual
jharmke posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Samsung Type of Appliance: refrigerator Model Number: RF29DB970012 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Hi, Can you get the Samsung RF29DB970012 service manual? Thanks, Jim -
jason.arthur.taylor.1 started following Maytag - 20.5 Cu. Ft. Top-Freezer/Refrigerator MRT311FFFZ not cooling enough?
jason.arthur.taylor.1 posted a topic in DIY Appliance Repair Help
Hi repair techs and enthusiasts. I have a refrigerator questions. We invested a lot of$$, about $1000, in this fridge, now a week old, and love everything except the cooling itself. There are 5 "lower" temperature settings and three "upper" freezer levels for 15 setting combos in total. The strongest lower setting is for emergencies only, and is called PowerCold. It works great, but it cannot be used for long times, so the strongest to use has all 4 leds on. On that setting, it takes 12-24 hours to get back to spec temperatures once you go grocery shopping. (This is with the freezer on the coldest setting, diverting most cooling air from the warmer fridge.) Spec temps are, IMO, -9F freezer and 40F refrigerator. Also, there are visible water droplets in the ducting area of the the fridge air exchange section. And if dampness or standing water in the crisper drawers, it doesn't dry, even when the vents are 100% open. But, to be honest, at 40F the vapor pressure is going to be low so I don't know. There are droplets accumulating on the outside of the lower hinge of the freezer drawer. I'm guessing the installer messed up with the hinge swap. The design has the warmer, high-pressure-region (i.e., condenser) fins on the bottom. It's a great use of space and aesthetics. A fan mounted sideways in the rear bottom sucks cooling air in from the front, with some cardboard below the evaporator coils to help direct the air to move past the coils. During operation, these fins only get up to about 92.5 F in 74 F ambient air. I have another fridge I have to use for more robust cooling and it's coils are at 102 F, and mounted vertically, allowing more traditional convective cooling of them. The cooling seems very weak to me. Is it possible to upgrade the rear fan speed? Is there an easy way to test if the amount of refrigerant installed at the factory is correct? Should I get a different brand that cools better? If so, what brand? I'm constrained on a few things like width and bottom-mounted freezers are ruled out due to ice tray tilting mishaps when bending down. -
jason.arthur.taylor.1 joined the community
Tech sheet / manual needed Bosch dw SHS43CF5N/01
Son of Samurai replied to thepowertowin's topic in Appliance Service Manual Requests Forum
Uses this manual: The schematic in this bundle: The check routine request and error codes in this bundle: -
Thermador Refrigerator Service Manual Needed
Son of Samurai replied to humbleguy's topic in Appliance Service Manual Requests Forum
Uses this manual: And this parts list: -
New Appliance Service Manual added: Thermador T42BT120NS/02 Refrigerator Parts List
Thermador T42BT120NS/02 Refrigerator Parts List View File Thermador T42BT120NS/02 Refrigerator Parts List Submitter Son of Samurai Submitted 07/02/2025 Category Appliance Repair Manual Pot Luck Supper -
Tech sheet
Son of Samurai replied to ecappliancecompany's topic in Appliance Service Manual Requests Forum
Domo, Captain! -
New Appliance Service Manual added: KitchenAid KRFC300ESS07 Refrigerator Tech Sheet
KitchenAid KRFC300ESS07 Refrigerator Tech Sheet View File Pub Tech-Sheet-W11542405-Rev B Submitter Captain Dunsel Submitted 07/02/2025 Category Appliance Repair Manual Pot Luck Supper -
My fridge the other day was getting salad greens icy at back of fridge. To be honest, fridge was completely packed. This morning, freezer contents were defrosting, even though LED for freezer said -2. Clearly NOT -2 in freezer if ice cream melting. I cleared out stuff from fridge and freezer. Ran a blow dryer in back of freezer to make sure no ice. Unplugged fridge, waited, plugged back in. LED then read 46 for freezer when I plugged back in…but after a while, eventually went back down to -2. But thermometer in freezer reads much warmer. Can the ok LED temp shown be wrong? When I put my hand inside freezer, it doesn’t seem as cold as LED reading. (Inside fridge temp is same as LED reading 38) The refrigerator section seems to be working fine. How long, if freezer components working properly do I have to wait for freezer temperature to be correct? (since I’ve been constantly checking the freezer, the LED temp has risen to 1. But Taylor old fashioned thermometer inside freezer reads 30—which is 16 degrees lower than LED read when plugged back in) By the way, I can hear refrigerator is running. I am just trying to determine if this might be on the road to recovery or get help…which on this holiday weekend might be impossible! thanks.
Captain Dunsel started following GE fridge freezer warm
Whirlpool WTW5010LW0 lid lock clicking on/off
Mufasa replied to Mufasa's topic in DIY Appliance Repair Help
will check, thank you. -
Need Complete Service Manual and Tech sheet 10656546400
There is really no exact manual for this! Uses the same wiring diagram as this model: Indoor ice maker: This may not apply but here you go:- 1 reply
- 1
drew 83 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Kenmore Type of Appliance: Refrigerator Model Number: 10656546400 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for complete service Manual and tech sheet for 10656546400 , Thank you!! -
Daniel.A replied to Son of Samurai's topic in Announcements
Couldn't agree more with this! Great job @Nathaniel Peterson! You've certainly earned this badge, and I continually enjoy reading your input on the forums. You've got a lot of sound knowledge, wisdom and experience! -
thepowertowin posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHS43CF5N/01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for diagrams, etc. to help with a not powering on issue. Will light up on breaker cycle, 5 seconds, then go out and won’t power on. SHS43CF5N/01 -
Casualcamo replied to Mufasa's topic in DIY Appliance Repair Help
It is possible that it is bad. The specs may have something you can find for a resistance check. I've never herd of the shifter causing the no lock issue before, but its either gonna be lid lock or board. Veryfi that its getting power from the controller. if its powered and not locking then switch, if your seeing drops in power when it should be locked then board. -
Casualcamo replied to bldn10's topic in DIY Appliance Repair Help
Have you looked at any fans? -
yes if the element gets hot at all its working. So to make sure i understand both elements have continuity, The have voltage, and you replaced the sensor and control board? -
Ge washer gtwn7450d0ww control board programming
johntech replied to johntech's topic in Appliance Service Manual Requests Forum
Thank you. -
Insignia NSDWH1SS9 dishwasher service manual request
Nothing here!
Blog Entries
2 comments
Topics
