  2. Manufacturer: Frigidair Type of Appliance: French door fridge Model Number: Frfg723av03 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need complete service manual, found tech sheet
  3. Anyone ever seen this type of issue with Samsungs?
  4. Today
  5. @Centre St-Exupery I just got this service manual that is current and also a copy of the wiring diagram.Uploading and waiting on approval:
  6. Kvberry13
    Control board Repair pics
  7. Yesterday
  8. MrApplianceMatt
    Personality Codes...Where do you find them?
    It should be listed in the tech sheet taped to the inside of the washer, otherwise, here's a breakdown I found... https://www.manualslib.com/manual/1254374/Ge-Htw200ask_ww.html?page=44
  9. Working on a GE top load washer Model # GTW460ASJ9WW serial #LL142320G. I have seen some say the personality number is 11 on this model and also seen some that said it was a 3. Anyone have any idea what personality number this washer may be. It would check something off my troubleshooting list if any one knows. I have checked it on the service mode and it appears as three. Thanks in advance for any advice.
  10. Been researching this type of pressure switch far and wide and came up empty. (I bought another pressure switch from Bosch just in case- different design, with a factory-set adjustment screw under the housing which is held on with 3 tabs.) I'm going to try to make the tube longer. The nipple on the pressure sensor measures about 7/32" (.217"-.218") so that tells me 3/16" ID tubing will work with a 3/16" barbed connector. Just trying to figure out where do I put the slop so it doesn't chafe or get in the way. The original tubing is this black rubber star-shaped tubing, but I will extend (and not alter) with standard vinyl tubing.
  11. Rich Armstrong
    Service Manuel Request
    Thank you Captain
  12. GE Washer Personality Program Procedure WH22X32817 Part Install Instructions View File Pub 99-3000259 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
  13. GE Part Instructions Wi-Fi Module Kit WH22X33297 View File Pub 99-3000273 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
  14. GE Washer Personality Program Procedure WH22X37219 Part Install Instructions View File Pub 99‐3000379 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
  15. GE Washer Personality Program Procedure WH22X38440 Part Install Instructions View File Pub 99‐3000379 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
  16. GE Washer Personality Program Procedure WH22X38517 Part Install Instructions View File Pub 99-3000297 Rev 1 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
  17. GE Washer Personality Program Procedure WH22X38558 Part Install Instructions View File Pub 99-3000406 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
  18. Last week
  19. I have an LG DLGX2502V dryer that just started tripping thermal fuse. I disassembled the exhaust duct work and cleaned it, though it was not very bad at all. I reassembled and ran it on air dry just to check exhaust flow, good exhaust at outside vent baffle. Still no heat, found the thermal limit fuse, was able to reset it and it ran, gas came on, and it seemed to be heating up fine. Shut it off, later on added wet clothes and ran it. Limit switch tripped again. Bad limit switch? What should I check. Thanks in advance.
  20. Captain Dunsel
    This should work:
  21. Manufacturer: Kenmore/LG Type of Appliance: Top load Washer Model Number: 79631512210 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Low water fill
  22. Try this one:
  23. Manufacturer: Huebsch Type of Appliance: Dryer Model Number: DR5102WE ZDE6HRYS177CW01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Huebsch DR5102WE ZDE6HRYS177CW01 dryer service manual request Thank you
  24. Version 1.0.0
    0 downloads
    Pub 99-3000273
  25. Appliance Fixer 68
    Whirlpool WTW4816FW3 washer sounds like a jet engine
    I have a newer Whirlpool washer, model WTW4816FW3, that is very loud on the spin cycle and sounds like a jet taking off. It’s not banging and it’s not extremely off balance but when the spin cycle is very loud. No other issues, it’s just loud on the spin cycle. I purchased this machine in 2023. Every time I do laundry it’s very loud on the spin cycle.
