  2. Manufacturer: Kenmore Type of Appliance: Washer Model Number: 796.51993.610 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need a service manual and any service bulletins for LG built pedestal washer Model 79651993610. Thanks
  3. Robert Couchman
    Thank you for answering my query, let me see if I can explain what I discovered. I desoldered the full wave rectifier that is adjacent to the two caps and found that the hot glue that had been used to mechanically attach the capacitor had flowed underneath the rectifier, become carbonized and therefore conductive and that's what was arcing. I cleaned up the carbonized hot glue replaced. The full wave rectifier and everything seems to be working swimmingly. I'll post some pictures for your edification. Thanks again to everybody who contributed.
  4. Today
  5. Here you go:
  6. Manufacturer: Frigidaire Type of Appliance: Refrigerator Model Number: FGHB2868TF4 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual for FGHB2868TF4, thanks!
  7. Captain Dunsel
    tech sheet needed for frontload washer
    This should work:
  8. Manufacturer: samsung Type of Appliance: frontload washer Model Number: wf393btpara/a2 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes tech sheet needed washer continuing to spin for hours after until you stop it manually
  9. until
    All are invited to join in the conversation for all things Appliantological: bidness, customers, tools, troubleshooting, flavorite brewski, whatever. Webcams and microphones are open and live! Also, follow this Calendar Event so you'll get notified of new posts here. Look for the "Follow" button either at the top of the topic on desktop or below the topic on mobile. Who: This workshop is available to everybody, including you! You don't have to be a member of Appliantology to join the fun. When: Saturday, July 12 @10:00 AM Eastern Time. Where: Online via Zoom How: Click here to register. If you're interested, register now. Arrive a couple minutes early to make sure your connection is working. Set a reminder for yourself for this workshop so you don’t miss it.
  10. Rich Armstrong
    Bosch Dryer Service Manual
    Thanks Captain!
  11. Really trying to determine failure of User Interface or Control Unit or both. The Diagnostic mode has two methods of initiating, using the Spin Soil and Temperature buttons or rotating the dial CCW and CW. Both methods could not reach Diagnostic mode. So am I left with the most expensive part Control Unit to replace? It's OK I can take it. Thank you in advance.
  12. Manufacturer: Dacor Type of Appliance: Wall Oven Model Number: ECS227SBK Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for tech sheet or service manual for this Dacor wall oven. TIA
  13. Yesterday
  14. Manufacturer: Thermador Type of Appliance: Refrigerator Model Number: T42BT120NS/02 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hello. I need help finding the service manual and hopefully the parts list for this Thermador refrigerator. Model#T42BT120NS/02. Thanks in advance brethren!
  15. Captain Dunsel
    This service manual: This wiring diagram: See if this helps also:
  16. Manufacturer: Bosch Type of Appliance: Dryer Model Number: WTMC6300US/01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I need full service manual Captain. Thanks!
  17. My washer stops after the wash cycle and drain is complete, wash light flashing, try to start pressing start button and flashes again after a minute or so. Fault code shows F5e2, F2E1, F5E3. Replaced lid switch and still have the problem. Attempted to run manual test but don’t know the sequence of function test, tech sheet doesn’t show it, never saw a lid switch test. It fills and drains and agitates and spins in the test. In automatic test it seems to test everything but the lid switch??? Don’t understand why. Do you think it is the controller? Don’t know if I want to buy a controller. Any suggestions on what else I can check? Any advice would be appreciated, thanks
  18. Captain Dunsel
  19. Manufacturer: Frigidaire Type of Appliance: Refrigerator Model Number: FRSS26L3AFC Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I found a tech sheet for a FRSS26 but the ice maker diagnostics is not the same. The fridge I'm working on doesn't have a numeric display.
  20. vee8power
    Tech sheet
    Did you see this one?
  21. ecappliancecompany
    Tech sheet
  22. Yes, the dreaded Whirlpool side by side wire cluster debacle
  23. Whirlpool has a huge problem with this. They can’t make a wire harness to save their life. It’s what I call “damaged beyond reasonable” as I would realistically need to replace the door and the harness and that type of money isn’t realistic for the customer. So I just have them call whirlpool and scream at them. Also it happens again and again due to lack of slack and the design. It’s a catastrophe. The more they open and close the door, the more and more the wires get tugged on, the more and more they rip.
  24. Mr. Appliance of Mentor
  25. Last week
  26. Hi Appliantology Community, I’m a recent graduate of the Appliantology Core Appliance Repair course and am currently working through advanced modules (e.g., refrigeration, washer/dryer, stove/oven repair, etc.). I’m eager to gain hands-on experience and apply what I’ve learned. I’m looking for an experienced technician in the Dallas area who would be open to letting me shadow them on weekends and/or evenings. My goal is to learn the ropes and gain real-world experience to complement my training. I’m detail-oriented, committed, and open to transitioning to part-time work once I’ve gained more experience. If you’re open to mentoring or know someone who might be, I’d love to connect. Please feel free to send me a message to discuss further. Thank you, Ryan
      • 1
      • Like
  27. Maytag MHW5500FW1 front load washer acting like somebody is holding the buttons down. Accepts user input while randomly changing other options. ON/Off reactive touch button does not work. Dial acting as on/off as well as it's normal duties sort of. Will start cycle then beep trying to change options, may finish cycle or not. Also acts like the Delay Start button is constantly pressed cycling thru 1hr -12hr delay steps. Removed and inspected the User Interface, wiped down but was clean and dry, no improvement. Thank you.
  28. When I touch the filter status button I get an ERR on the display. Have removed/replaced the filter a couple times same result. Can't seem to get it to reset.
  29. Budget Appliance Repair
