  2. It sounds like a few things might be going on but it's hard to tell from this video. The drain pump sounds loud so I would investigate that for a blockage or restriction. Check for any play between the spin basket and the tub as that would indicate a bearing or basket support arm failure. Pull the back panel off and look for signs of leakage from the basket drive shaft. There should be some technical information tucked under the top somewhere. I would look for error codes to see what the control board thinks is wrong and why it's limiting spin speed.
  3. MrApplianceMatt
    Whirlpool WTW5000DW0 bearing repair?
    This would require a gear box replacement. The gear box is self contained and is not designed to be rebuilt. It includes the tub seal. Is there any lateral play between the tub and the basket? If so, then this would require replacing the basket as well. These machines were designed for economy, not longevity.
  4. Yesterday
  5. Thanks!
  6. I have a Whirlpool top load washer that has became rather loud on the spin cycle and I’m pretty sure it’s due to a bearing going out. Do they sell a bearing kit for this model?
  7. Captain Dunsel
    Request for Service Manual
  8. Manufacturer: Kenmore Type of Appliance: Electric Range Model Number: 790-94149310 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Please provide the service manual for Kenmore Electric Range model # 790-94149310
  9. Captain Dunsel
    Kitchenaid Refrigerator Tech manual
    Uses the same tech sheet as this model: This troubleshooting Guide comes up: May have some similarities to Parts of this manual:
  10. Manufacturer: Kitchenaid Type of Appliance: Refrigerator Model Number: KRFC704FPS01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Need a tech sheet or manual, please. Thanks
  11. Uses this mini manual.No exact service manual but you can work off these! This one: This one: And this:
  12. Manufacturer: GE Type of Appliance: Refrigerator Model Number: GSS25GSHBCSS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual for GSS25GSHBCSS
  13. Uses this manual: Uses this bundle:
  14. Thermador DWHD650WFP/01 Dishwasher Service Manual View File PUB 58300000211238 Submitter Son of Samurai Submitted 05/15/2025 Category Appliance Repair Manual Pot Luck Supper
  15. Version 1.0.0
    3 downloads
    PUB 58300000211238
  16. Manufacturer: Thermador Type of Appliance: Dishwasher Model Number: DWHD650WFP/01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need to request service manual/tech sheets for Thermador dishwasher model # DWHD650WFP/01
  17. Last week
  18. This should work for you:
  19. Manufacturer: Kenmore Type of Appliance: dishwasher Model Number: 630.13953011 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): y I need a tech sheet for a 630.13953011 dishwasher please
  20. At first it was doing this intermittently and we thought it was a balancing issue. Now, it's every time. Although the machine does spin, it never spins fast and the clothes come out sopping wet. Doesn't matter how big the load is. I've tested it with one or two T-shirts and it still doesn't spin. Any ideas? Also, what is it that engages and makes that noise at 0:22 in the video?
  21. StaggsHomeAppliance
    Midea Refrigerator E6 Error Code
    @Captain Dunsel thank you!
  22. Much thanks Captain!!
  23. Thanks for the help. There only 3 switches, the top should be NO (Primary) and the middle should be NC (Second), and the last should be NO (Door sensing)? What puzzles me that all the switches were the same and it still works.
  24. No parts list, tech sheet comes up for this model on servicematters or anywhere.It is a good model number though!
  25. Manufacturer: Viking Type of Appliance: Under counter drawer microwave oven Model Number: Vmod5240ss Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need complete service manual
  26. Captain Dunsel
    I look at the user manual and parts list and maybe this model would be close to what you have.Take a look!That's why I uploaded it.
  27. Captain Dunsel
    GE Washing Machine Schematic
    I am not finding a parts site that identifies the mini manual for that model. Guessing maybe it is in this ball game!
  28. citizenX
    Maytag Washer is Very Loud on Spin Cycle
    If by loud, you mean sounds like a jet taking off in spin and the noise ramps up the faster it spins? If so, that sounds like a bearing in the gearcase and the only fix is to replace the gearcase. It's not a terribly difficult job but the part alone is upwards of $300. There are videos on YouTube showing how to do it if you're so inclined.
