Upcoming Events
- Past hour
Sherif joined the community
- Today
Captain Dunsel started following Frididaire SxS Tech Sheet Needed
Captain Dunsel replied to Techlyne's topic in Appliance Service Manual Requests Forum
Uses the same tech sheet as this model:- 1 reply
- 1
Techlyne started following Frididaire SxS Tech Sheet Needed
Manufacturer: Frigidaire Type of Appliance: Refrigerator Model Number: FRSS26L3AFC Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I found a tech sheet for a FRSS26 but the ice maker diagnostics is not the same. The fridge I'm working on doesn't have a numeric display.
Vlad Sova joined the community
vee8power started following Tech sheet
Tech sheet
vee8power replied to ecappliancecompany's topic in Appliance Service Manual Requests Forum
Did you see this one?- 1 reply
- 1
AustinHines started following Vance R
Wire Piercing Probes in Action - Locating breaks in Whirlpool SxS Lower Hinge Wiring
bowhunter commented on Rhubarb Tau's blog entry in Rhubarb Tau's Sloggy Vlog Blog Bog
Yes, the dreaded Whirlpool side by side wire cluster debacle -
Mr. Appliance of Mentor commented on Rhubarb Tau's blog entry in Rhubarb Tau's Sloggy Vlog Blog Bog
Whirlpool has a huge problem with this. They can’t make a wire harness to save their life. It’s what I call “damaged beyond reasonable” as I would realistically need to replace the door and the harness and that type of money isn’t realistic for the customer. So I just have them call whirlpool and scream at them. Also it happens again and again due to lack of slack and the design. It’s a catastrophe. The more they open and close the door, the more and more the wires get tugged on, the more and more they rip. -
Mr. Appliance of Mentor commented on Son of Samurai's blog entry in Appliance Repair Tech Tips
Good one. That could totally throw someone off if they aren’t paying close attention to what is actually happening. I could see someone ordering a board or something lol -
Thornhill777 started following Vance R
Thornhill777 joined the community
VSK joined the community
- Yesterday
Darci joined the community
Looking for Mentorship and/or Shadowing Opportunity in Dallas, TX
Hi Appliantology Community, I’m a recent graduate of the Appliantology Core Appliance Repair course and am currently working through advanced modules (e.g., refrigeration, washer/dryer, stove/oven repair, etc.). I’m eager to gain hands-on experience and apply what I’ve learned. I’m looking for an experienced technician in the Dallas area who would be open to letting me shadow them on weekends and/or evenings. My goal is to learn the ropes and gain real-world experience to complement my training. I’m detail-oriented, committed, and open to transitioning to part-time work once I’ve gained more experience. If you’re open to mentoring or know someone who might be, I’d love to connect. Please feel free to send me a message to discuss further. Thank you, Ryan-
- 1
Kmhogan joined the community
Inqo joined the community
Eng89 joined the community
NPerry joined the community
But what about the really loud sound on spin cycle. It’s like a jet engine in our laundry room (very loud). - Last week
Tech sheet needed
Here you go:- 1 reply
- 1
Any updates? Need it too
Thanks, Captain! -
T18ID905LP/11
Manufacturer: Thor Type of Appliance: Range Model Number: FFSGS6291-36 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yea Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need to request service manual for Forno range model FFSGS6291-36 -
service manual above
Blog Entries
2 comments
Topics
