  2. You may have gookus(technical term for nasty, unwanted blockage) in the pressure switch hose, or the air dome in the tub. If that doesn't help, it's the control board. Disassembly will be something like this: I
  3. My Whirlpool Cabrio washer randomly starts to drain. I’ve had the washer for 3 weeks, came with the house, and twice now while not in use, no lights on control panel, no water in the tub it starts draining. It drains for about 60-90 seconds, stops for 30 seconds and then drains again for another 60-90 seconds then stops. Is this normal? Is this the way this washers works? Thanks
  4. Today
  5. As the title says, there's an abnormal noise that occurs frequently (but not always) during the spin cycle. It doesn't seem to change with the size of the load. Washer is just over a year old (of course!). Attached video. Any ideas? PXL_20250214_200016260.TS.mp4 Thanks!
  6. I had a GE dryer a month or two back that had experienced a power surge that reset the personality. Maybe check and see if the personality for the board is mismatched for the model?
  7. Jason Munson
    Rest in peace, Terry Carmen
    Sad to hear about this, Terry was always very helpful. Rest in Peace
  8. Yesterday
  9. Captain Dunsel
    Sub-Zero IC-24FI Service manual
    You should be able to use this manual:
  10. Son of Samurai
    Insignia NS-FDRE67WH8A-C D/R SM Request
    Thanks, Cap!
  11. Thanks, Cap!
  12. Manufacturer: Sub-zero Type of Appliance: Column freezer Model Number: IC-24FI Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Seeking servicemanual for this Sub-Zero column IC-24FI
  13. Insignia NS-FDRE67WH8A-C Dryer Service Manual View File Pub No # Models: NS-FDRE67WH8A-C NS-FDRE67WH8A NS-FDRG67WH8A Submitter Captain Dunsel Submitted 05/09/2025 Category Appliance Repair Manual Pot Luck Supper
  14. Whirlpool WRX735SDHV10 Refrigerator Tech Sheet View File Pub Tech Sheet - W11665549 - Rev A Submitter Captain Dunsel Submitted 05/09/2025 Category Appliance Repair Manual Pot Luck Supper
  15. Version 1.0.0
    1 download
  16. Uploading tech sheet and waiting on approval.
  17. Manufacturer: Whirlpool Type of Appliance: Refrigerator Model Number: WRX735SDHV10 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes WRX735SDHV10 tech sheet W11665549 needed. Thanks!!
  18. Maytag MDG4658AWW Dryer Tech Sheet View File PUB 16027552 Submitter Son of Samurai Submitted 05/09/2025 Category Appliance Repair Manual Pot Luck Supper
  19. Version 1.0.0
    1 download
    PUB 16027552
  20. Manufacturer: thermador Type of Appliance: bi fridge/frz Model Number: TI30IR70NSP/04 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes looking for wiring diag for /04... i'm assuming the service guides posted Aug 16, 2017 will work for this /04 version thanks PS, could probably use a parts diag or manual if there is one for this /04
  21. Dynamic Appliance Repair
    GE Single Wall Oven JT3000SF6SS overheating
    Over a year later..
  22. You are hilarious
  23. Captain Dunsel
    Need complete service manual
    @drew 83 no complete manual for this one.see if any of this helps is the best I can do! Also this:
  24. Version 1.0.0
    0 downloads
  25. Captain Dunsel
    Uploading service manual and waiting on approval:
  26. Manufacturer: Kitchen aid Type of Appliance: Side by side fridge Model Number: Ksrb25frbx00 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Found tech sheet but looking for complete service manual.
  27. Thank you @Captain Dunsel!
  28. Joe B, Stoughton Appliance Repair
    Samsung Side Vent installation
    Thanks. Job went well. Was able to do the conversion through the rear and side vent openings. No disassembly, but high risk of sharp edges: wear sleeves. Knockout side port and there is plenty of room to work. Taping elbow joints properly is the biggest challenge. Long Phillips extension (with magnet) needed to secure front mounting screw. Taping joints, difficult but possible. 1/8” drill bit needed for pilot hole exterior mounting screw.
