  2. Manufacturer: Thermador Type of Appliance: Refrigerator Model Number: T42BT120NS/02 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hello. I need help finding the service manual and hopefully the parts list for this Thermador refrigerator. Model#T42BT120NS/02. Thanks in advance brethren!
  3. Captain Dunsel
    Bosch Dryer Service Manual
    This service manual: This wiring diagram: See if this helps also:
  4. Manufacturer: Bosch Type of Appliance: Dryer Model Number: WTMC6300US/01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I need full service manual Captain. Thanks!
  5. Today
  6. My washer stops after the wash cycle and drain is complete, wash light flashing, try to start pressing start button and flashes again after a minute or so. Fault code shows F5e2, F2E1, F5E3. Replaced lid switch and still have the problem. Attempted to run manual test but don’t know the sequence of function test, tech sheet doesn’t show it, never saw a lid switch test. It fills and drains and agitates and spins in the test. In automatic test it seems to test everything but the lid switch??? Don’t understand why. Do you think it is the controller? Don’t know if I want to buy a controller. Any suggestions on what else I can check? Any advice would be appreciated, thanks
  7. Captain Dunsel
  8. Manufacturer: Frigidaire Type of Appliance: Refrigerator Model Number: FRSS26L3AFC Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I found a tech sheet for a FRSS26 but the ice maker diagnostics is not the same. The fridge I'm working on doesn't have a numeric display.
  9. vee8power
    Tech sheet
    Did you see this one?
  10. ecappliancecompany
    Tech sheet
  11. Yes, the dreaded Whirlpool side by side wire cluster debacle
  12. Whirlpool has a huge problem with this. They can’t make a wire harness to save their life. It’s what I call “damaged beyond reasonable” as I would realistically need to replace the door and the harness and that type of money isn’t realistic for the customer. So I just have them call whirlpool and scream at them. Also it happens again and again due to lack of slack and the design. It’s a catastrophe. The more they open and close the door, the more and more the wires get tugged on, the more and more they rip.
  13. Mr. Appliance of Mentor
  14. Yesterday
  15. Hi Appliantology Community, I’m a recent graduate of the Appliantology Core Appliance Repair course and am currently working through advanced modules (e.g., refrigeration, washer/dryer, stove/oven repair, etc.). I’m eager to gain hands-on experience and apply what I’ve learned. I’m looking for an experienced technician in the Dallas area who would be open to letting me shadow them on weekends and/or evenings. My goal is to learn the ropes and gain real-world experience to complement my training. I’m detail-oriented, committed, and open to transitioning to part-time work once I’ve gained more experience. If you’re open to mentoring or know someone who might be, I’d love to connect. Please feel free to send me a message to discuss further. Thank you, Ryan
      • 1
      • Like
  16. Maytag MHW5500FW1 front load washer acting like somebody is holding the buttons down. Accepts user input while randomly changing other options. ON/Off reactive touch button does not work. Dial acting as on/off as well as it's normal duties sort of. Will start cycle then beep trying to change options, may finish cycle or not. Also acts like the Delay Start button is constantly pressed cycling thru 1hr -12hr delay steps. Removed and inspected the User Interface, wiped down but was clean and dry, no improvement. Thank you.
  17. When I touch the filter status button I get an ERR on the display. Have removed/replaced the filter a couple times same result. Can't seem to get it to reset.
  18. Budget Appliance Repair
  19. Budget Appliance Repair
  20. Mr. Fox6000
  21. Last week
  22. Captain Dunsel
    Tech sheet needed
    Here you go:
  23. ecappliancecompany
    Tech sheet needed
  24. 98repair
    Miele G6625 SCU
    Any updates? Need it too
  25. I hope I'm following protocol here, I had a thread going about the defroster problem which is now I believe solved but on the way there I ran into a new problem. While I was waiting for the defrost heater sensor replacement to arrive, I pulled the cover off the back of the refrigerator. Anticipating that I might have to replace the control board if this part didn't do the job. At some point with the defrost heater still disconnected. I imagine I could plug the refrigerator in and get the fridge section to cool down saving my food from completely warming up. The minute I plugged the unit in there was some arcing on what I now know is the compressor control board. I waited until the replacement part. That is the defrost heater. Temperature sensor arrived, reinstalled it and then again plug the unit in and again there was arcing on this board. I removed the board. Looks to me like it's a rectifier full wave rectifier and the arcing. Is that the top of the board as you're looking at it from my troubleshooting experience? It's rare that there are two concurrent problems, but that appears to be the case. I can't think of anything that I did along the way to cause this bridge rectifier to fail. I'm actually thinking that I can procure the bridge rectifier and replace it on the board, but I'm open to suggestions. It looks like it's a pretty common board available on Amazon and other places. The illustrated replacement boards lack the second cap that appears on the upper right section of this board. The board number is itrp 04bx1.a. thanks for your help
  26. Akshesh
  27. Thanks, Captain!
  28. Forno FFSGS6291-36 Gas Range Installation Guide View File Pub 5015011 Submitter Captain Dunsel Submitted 06/27/2025 Category Appliance Repair Manual Pot Luck Supper
  29. Son of Samurai
    T18ID905LP/11
