  2. Son of Samurai
    Thermador cooktop
    Unfortunately, Bosch's info on this model was very sparse. That was the only helpful doc I found.
  3. Yesterday
  4. Manufacturer: Thermador Type of Appliance: Dishwasher Model Number: DWHD770WFM/17 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual
  5. How do I check for fan voltage? At the board. I think it should be 12-14. If it's the board what connector and wires should I check? Thanks
  6. That feature usually is only on higher end refrigerators. Even though it would cost that much per refrigerator the cost of 1000's of them not having actual temperature display isn't worth it to them. As it'll eat into the profits.
  7. Condensor fan is running although RPMs seem lower than other fans based on the diagnostic tests. UPDATE: Left it plugged in and after 6 hours, sure enough, the visible internal freezer fan was now running and temps cooler. Left it full 24 hours and freezer froze water and fridge cool. Another 24 hours and freezer temp is set at zero degrees but showing 6-8 degrees on my thermometer. Refidge side is set for 37 and showing 39-41 on my thermometer which might be off. Ice maker and water dispenser work as well. Seems like it is running correctly although I wish it would display its own temperature readings instead of just the set points.
  8. Last week
  9. Captain Dunsel
    Follow these instructions: HIDDEN BAKE ASSEMBLY To Remove 1. Disconnect power. 2. Pull unit out so left side is exposed. 3. Prop up or remove cooktop (see cooktop removal section). 4. Remove outer side panel via visible hex screws and one blind screw inside front of drawer compartment. 5. Remove side insulation retainer via two screws mating with base, and unhooking wire insulation retainers at the top. 6. Disconnect hidden bake ground wire and unplug hidden bake element. 7. Inside the oven cavity, remove screw in lower left corner. 8. Slide hidden bake assembly out from under oven. To Replace 1. Make sure the bottom insulation is fully covering the bottom of the base module. 2. Slide the hidden bake assembly in from the side, being careful not to dis- place the insulation. 3. Reattach side insulation retainer and hidden bake ground wire. 4. Reconnect screw at lower left inside oven cavity. 5. Plug hidden bake wire harness into element terminals. 6. Reattach outer side panel and cooktop. 7. Plug in unit, test and slide back into place. COOKTOP REMOVAL SECTION: To Remove 1. Disconnect power. 2. Remove the 2 screws securing front of cooktop to chassis. 3. Prop up the cooktop, and unplug the connectors at the back by squeezing side tabs. Remove screw securing ground wire. 4. Lift the back end of the cooktop up about 2 inches to unhook the hinge pins from the brackets. 5. Reverse the process to reinstall. CAUTION: Raising the cooktop too high can break the glass.
  10. DIY_Hopefully
    My apology! The model is actually JB910S L6SS. There is no visible element on the bottom of the oven so I am having trouble using the exploded parts diagram. I plan to test/check each potential part that may be causing this very slow heating. Is the element beneath the oven floor, but above the drawer under the oven -- or is the element in the back by the convection fan? Since it heats up (eventually), assuming electrical continuity of the element, how can I test the relay and test the control board? Please indicate the corresponding part numbers from the above diagram. Many thanks!
  11. N1kon01
    Thermador cooktop
  12. Thanks, got the floodstop unit (new, replaced ancient one) fixed - turns out some of these new units were installed with the gears backwards in the motor, so when you hit closed, the valve would open, and open the valve would close - so when you poured a bit of water on the sensor, it would OPEN the valve and not CLOSE it as it should - victory! So now on to try to get the stove apart enough to take a pic of the thermostat to see if it is rebuildable or not, the company that rebuild my gas safety valve said it may be too current of a model to be rebuildable, but worth a shot to see a pic. If not, then it looks like I will be looking at going your way with trying to find a replacement. It is surprising to me that since they made these stoves with standing pilot until just a couple of years ago that a modern replacement thermostat would not work, now they are all electronic ignition.
  13. ATOSA MBF8000 Series Vertical Coolers and Freezers Instruction Manual View File Instruction manual for ATOSA MBF 8000 series vertical cooler/ freezer Submitter d915byrd Submitted 05/28/2025 Category Appliance Repair Manual Pot Luck Supper
  14. Son of Samurai
    Thermador range
  15. Son of Samurai
    Thermador cooktop
    Here you go:
  16. Thermador PC486GDBS/01 Cooktop Schematic View File PUB 58300000103877 Submitter Son of Samurai Submitted 05/31/2025 Category Appliance Repair Manual Pot Luck Supper
  17. Version 1.0.0
    3 downloads
    PUB 58300000103877
  18. Captain Dunsel
    Thermador range
    Looks like you can use this:
  19. Sorry for the delay on this one -- here it is:
  20. Thanks, Cap!
  21. GE Front Load Dryer Main Board Programming Part WE22X39117 install Instructions View File Pub 99-3000285 Rev. 2 Submitter Captain Dunsel Submitted 05/30/2025 Category Appliance Repair Manual Pot Luck Supper
  22. Kenmore 970-C97912-10 Laundry Center Parts List and Wiring Diagram View File Pub 5995501227 Submitter Captain Dunsel Submitted 05/29/2025 Category Appliance Repair Manual Pot Luck Supper
  23. GE GBVH6260 Washer Mini Manual View File Pub 31-15581 Models: GBVH6260 GCVH6260 WCVH6260 WBVH6240 WHDVH626 Submitter Captain Dunsel Submitted 05/29/2025 Category Appliance Repair Manual Pot Luck Supper
  24. Is the condenser fan running/getting power? Can't transfer heat without that running with the compressor with the back cover on and attached. Take a picture of the evaporator while it's been running awhile. If compressor is running what's the amp draw?
  25. Nathaniel Peterson
  26. Nicholsseand
    Frigidaire Range Tech sheet please
    Thanks Captain!
  27. You can use this service manual: Looks like a stand alone ice maker! Uses the same tech sheet as this model:
