Upcoming Events
- Past hour
igloo started following Rhubarb Tau's Sloggy Vlog Blog Bog
lactose joined the community
Rhubarb Tau started following Making Better Hose Clamp Pliers, Pt. 2
Rhubarb Tau posted a blog entry in Rhubarb Tau's Sloggy Vlog Blog Bog
Mini update, really. After tooling up the lathe a little more and getting some more practice in, I've made a first set of jaws. I ended up making several of the male side first, getting quite a bit more efficient, but until today I didn't have a tailstock chuck for the center-drilling. They're not the work of a pro, and the dimensions may need to be tweaked, but I think they might be serviceable. Next up, unbox and set up the MIG welder I bought a while back - Today
Cool Thank you Captain!
Landyn Basham joined the community
- Yesterday
Asusgamer joined the community
dmart4444 joined the community
Rukus joined the community
Captain Dunsel started following LG Refrig Service Manual
Captain Dunsel replied to MsAnn's topic in Appliance Service Manual Requests Forum
You should be able to use this manual: -
MsAnn started following LG Refrig Service Manual
Manufacturer: LG Type of Appliance: Refrigerator Model Number: LFXC24726S Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I need service manual and parts lists LFXC24726S thank you
Matt Henehan joined the community
MrApplianceMatt started following Intermittent squealing? noise during spin cycle. Samsung top-loader WA55A7300AE
MrApplianceMatt replied to firecat53's topic in DIY Appliance Repair Help
Possibilities include but are not limited to: bad washer clutch, loose rotor nut, bad bearing in gearbox. If memory serves this washer "clutch" is more of a shifter that's cable driven and that cable could stretch preventing full shifting. It's function is to lock the agitator to the basket for spin and to disengage for agitate. It could also be coming from a failing drain pump but that's hard to determine from this video. -
Qas1977 joined the community
Farmboy5878 joined the community
Whirlpool Cabrio Washer model WTW8000DW5 draining ?
dfphoto replied to tw200's topic in DIY Appliance Repair Help
If you're handy and tech oriented flip the machine and look for the tech sheet or it might be inside the console look at youtube to find out how then run diagnostic or calibrate it... - Last week
vee8power replied to tw200's topic in DIY Appliance Repair Help
You may have gookus(technical term for nasty, unwanted blockage) in the pressure switch hose, or the air dome in the tub. If that doesn't help, it's the control board. Disassembly will be something like this: I -
tw200 posted a topic in DIY Appliance Repair Help
My Whirlpool Cabrio washer randomly starts to drain. I’ve had the washer for 3 weeks, came with the house, and twice now while not in use, no lights on control panel, no water in the tub it starts draining. It drains for about 60-90 seconds, stops for 30 seconds and then drains again for another 60-90 seconds then stops. Is this normal? Is this the way this washers works? Thanks -
firecat53 posted a topic in DIY Appliance Repair Help
As the title says, there's an abnormal noise that occurs frequently (but not always) during the spin cycle. It doesn't seem to change with the size of the load. Washer is just over a year old (of course!). Attached video. Any ideas? PXL_20250214_200016260.TS.mp4 Thanks! -
GE top load washer GTW335asnww shuts down after filling
MrApplianceMatt replied to selfemployed's topic in DIY Appliance Repair Help
I had a GE dryer a month or two back that had experienced a power surge that reset the personality. Maybe check and see if the personality for the board is mismatched for the model? -
Rest in peace, Terry Carmen
Jason Munson replied to Samurai Appliance Repair Man's topic in Announcements
Sad to hear about this, Terry was always very helpful. Rest in Peace -
Sub-Zero IC-24FI Service manual
Captain Dunsel replied to Scottdottcom's topic in Appliance Service Manual Requests Forum
You should be able to use this manual:- 1 reply
- 1
Insignia NS-FDRE67WH8A-C D/R SM Request
Son of Samurai replied to JSMequipmentservices's topic in Appliance Service Manual Requests Forum
Thanks, Cap! -
WRX735SDHV10 tech sheet W11665549 needed. Thanks!!
Son of Samurai replied to Coley's topic in Appliance Service Manual Requests Forum
Thanks, Cap! -
Scottdottcom posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Sub-zero Type of Appliance: Column freezer Model Number: IC-24FI Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Seeking servicemanual for this Sub-Zero column IC-24FI -
New Appliance Service Manual added: Insignia NS-FDRE67WH8A-C Dryer Service Manual
Insignia NS-FDRE67WH8A-C Dryer Service Manual View File Pub No # Models: NS-FDRE67WH8A-C NS-FDRE67WH8A NS-FDRG67WH8A Submitter Captain Dunsel Submitted 05/09/2025 Category Appliance Repair Manual Pot Luck Supper -
New Appliance Service Manual added: Whirlpool WRX735SDHV10 Refrigerator Tech Sheet
Whirlpool WRX735SDHV10 Refrigerator Tech Sheet View File Pub Tech Sheet - W11665549 - Rev A Submitter Captain Dunsel Submitted 05/09/2025 Category Appliance Repair Manual Pot Luck Supper -
Captain Dunsel replied to Coley's topic in Appliance Service Manual Requests Forum
Uploading tech sheet and waiting on approval. -
Coley posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Whirlpool Type of Appliance: Refrigerator Model Number: WRX735SDHV10 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes WRX735SDHV10 tech sheet W11665549 needed. Thanks!! -
New Appliance Service Manual added: Maytag MDG4658AWW Dryer Tech Sheet
Maytag MDG4658AWW Dryer Tech Sheet View File PUB 16027552 Submitter Son of Samurai Submitted 05/09/2025 Category Appliance Repair Manual Pot Luck Supper -
Manufacturer: thermador Type of Appliance: bi fridge/frz Model Number: TI30IR70NSP/04 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes looking for wiring diag for /04... i'm assuming the service guides posted Aug 16, 2017 will work for this /04 version thanks PS, could probably use a parts diag or manual if there is one for this /04
GE Single Wall Oven JT3000SF6SS overheating
Dynamic Appliance Repair replied to Guaro DC's topic in DIY Appliance Repair Help
Over a year later.. -
LG Range LDE4413ST/00 manual request
Dwbingham replied to Aapltech's topic in Appliance Service Manual Requests Forum
You are hilarious
Blog Entries
Topics
firecat53 · Started
