  2. Here you go: This mini manual:
  3. Today
  4. I think you should do a test on a Front load washer dispenser hose especially tight area under the spring cross bar see pics I broke the nipple trying to get the clamp to move. clamp is under the crossbar just above the tub obviously serious pain
  5. Manufacturer: GE Type of Appliance: Washer Model Number: Gfw550ssn5ww Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I am in search of a service manual for a GE Gfw550ssn5ww front load washer. Thank you
  6. Captain Dunsel
    Samsung fridge tech sheet please
    Try this one:
  7. Manufacturer: Samsung Type of Appliance: Refrigerator Model Number: RF32CG5100SR Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Thank you!!
  8. Kenmore Elite 796.31523211 Washer Tech Sheet View File Tech sheet with service mode and wiring diagram Submitter MisFixIt Submitted 06/02/2025 Category Appliance Repair Manual Pot Luck Supper
  9. I'll have some more made soon, as soon as I troubleshoot the cutoff tool on my little shitty metal lathe. I think I'm going to sell a few to fellow techs for $50 plus shipping. I don't have a merchant site set up yet, but should soon. If you're down, you're on the list!
  10. Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHE878WD5N/01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES .
  11. Sorry for the late reply @Son of Samurai but thank you so much. Really appreciate it!
  12. Manufacturer: Deco Type of Appliance: Dryer Model Number: 860 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual
  13. Manufacturer: Deco Type of Appliance: Washer Model Number: 824 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual.
  14. Version 1.0.0
    1 download
  15. So yesterday I moved my refrigerator to paint behind it. I didn't unplug it or anything, just moved it forward so I could get behind it and then pushed it back. This morning the fridge was warm (about 60 degrees pretty close to room temp). I think the fridge is about 14 years old. The last time this happened, maybe 6 months ago I vacuumed the coils and it seemed to fix it. The coils don't look bad this time. I replaced the control board a few years ago. Someone suggested replacing the wiring harness and defrost thermostat at one point. It looks like that part (WPW10290745) can range from $65 - $200. Given the age of the appliance, is it worth it to try to replace that? As always, your advice is greatly appreciated. Thanks, Matt
  16. Yesterday
  17. Captain Dunsel
    GE in wall oven ZEK7000SH1SS
    No exact service manual for this one.Look at this one: Also look at this one: Uses this mini manual:
  18. Manufacturer: GE Type of Appliance: In wall oven Model Number: ZEK7000SH1SS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I have a ZEK7000SH1SS and the door latch died after self-cleaning. I would like a service manual that shows disassembly. Thank you.
  19. Whirlpool Top Load Washer and Stacked Laundry Service Pointer - F3E1 Pressure Sensor Error or Drain Pump Running Continuously S Code: S153EB View File Problem: F3E1 error code (pressure system fault) or drain pump continuously running. PUB W11766193 Rev C Submitter Samurai Appliance Repair Man Submitted 06/02/2025 Category Appliance Repair Manual Pot Luck Supper
  20. Version 1.0.0
    4 downloads
  21. Captain Dunsel
    Kenmore FG 596379243017 SM Request
  22. Manufacturer: Kenmore Type of Appliance: Refrigerator Model Number: 596.379243017 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes
  23. Manufacturer: Sub Zero Type of Appliance: Refrigerator Model Number: UW-24/S/PH-RH Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I need a tech sheet or service manual for this unit. Thank you
  24. brrappliancerepair
    Bad board? LFHG2251TF6
    Did you end up resolving this? I am battling same issue now. Replaced main board behind grill with no success. The failure is intermittent which makes this nearly impossible to diagnose. I was planning to replace either the UI board, the inverter board, or both...
  25. Samurai Appliance Repair Man
    Congratulations to our June 2025 Super Tech: Rhubarb Tau!
    Absolutely an Appliantology Super Tech! And be sure to check out Rhubarb's blog. Filled with all kinds of tech geekery that all appliance techs would be interested in:
  26. Manufacturer: Bosch Type of Appliance: Washer Model Number: WAT28400UC/14 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual request WAT28400UC/14
  27. Rhubarb Tau
    Holy Shit! You'll bleep that, right? I don't know what to say! Thanks everybody! I'll do my low-grade best to live up to this terrific honorific!
