  2. Manufacturer: Samsung Type of Appliance: Washer dryer combo Model Number: Wd53dba900hza1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Samsung Wd53dba900hza1 service manual request. Thank you
  3. You could cut off the small wire terminals off the wires and crimp on the bigger ones. The bigger ones are quarter inch, the most common size.
  4. Today
  5. What belt? I think you're thinking of a different model/brand.
  6. Captain Dunsel
    Kitchenaid Dishwasher MOD: KDPM704KPS0
    Here you go:
  7. Manufacturer: Whirlpool Type of Appliance: Dishwasher Model Number: KDPM704KPS0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Need tech sheet and/or svc manual for Kitchenaid Dishwasher MOD: KDPM704KPS0
  8. Captain Dunsel
    Kenmore DW 665.77969K703 SM Request
  9. Manufacturer: Kenmore Type of Appliance: Dishwasher Model Number: 665.77969K703 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes
  10. Manufacturer: Thor Type of Appliance: Gas range Model Number: Lrg4807u Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for tech sheet and or service manual
  11. until
    All are invited to join in the conversation for all things Appliantological: bidness, customers, tools, troubleshooting, flavorite brewski, whatever. Webcams and microphones are open and live! Also, follow this Calendar Event so you'll get notified of new posts here. Look for the "Follow" button either at the top of the topic on desktop or below the topic on mobile. Who: This workshop is available to everybody, including you! You don't have to be a member of Appliantology to join the fun. When: Saturday, May 24 @10:00 AM Eastern Time. Where: Online via Zoom How: Click here to register. If you're interested, register now. Arrive a couple minutes early to make sure your connection is working. Set a reminder for yourself for this workshop so you don’t miss it.
  12. How about 55000000073135
  13. Manufacturer: Bosch Type of Appliance: Dryer Model Number: WTG86403UC/01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hello Guys, I need the diagnostic test procedure for this machine. It usually comes as a separate page. The diagnostic test is not in the service manual nor in the error codes breakdown. Please help
  14. Thanks, greatly appreciated - new to this -
  15. Classic case—your Samsung WA55A7300AE likely has a failing bearing or worn drive pulley, both known weak points on these models. The intermittent squealing usually means early bearing wear or belt slippage. It happening regardless of load size backs that up. Since it’s just out of warranty (of course...), I’d recommend pulling the back panel and checking for belt wear or looseness first; bearings require more work and tools.
  16. For a 1980-era Premier 24" gas range, sourcing a direct replacement thermostat can be challenging due to discontinued parts. However, cross-compatible thermostats from brands like Robertshaw or White-Rodgers may serve as suitable substitutes. It's crucial to match specifications such as capillary length and temperature range. Consulting with appliance parts suppliers or professionals experienced in vintage range repairs can help identify a compatible thermostat.
  17. Just realized model number was wrong, GC21200W
  18. Posted a few years ago about needing my gas safety valve rebuilt, got that done - I have read thermostats operate differently on smaller gas ranges, but though my baked stuff has turned out okay, seems like thermostat overshoots a lot, and I notice that when I try turning the thermostat down from 350 - to 300 - to 250 - 200 - the dial thermometer I have towards the front of the rack doesn't show the temp going down, and when I pull the broiler door open the flame is still burning on the burner itself - Premier's parts number catalogs don't seem to go that far back, nor repair parts places, one poster stated the part number seems like ti may be incorrect, part missing - Premier doesn't have a thermostat for this, but they made standing-pilot 24" Premier stoves until recently, I would think there should be a cross reference where some of these would work. I am going to try to disassemble the range thermostat to get a pic of it, TOAC stated they may be able to rebuild it, but normally it is a bit too new for them to be able to do that? Thoughts?
  19. Yesterday
  20. GE top load washer Model # GTW460ASJ9WW serial #LL142320G. I have seen some say the personality number is 11 on this model and also seen some that said it was a 3. Anyone have any idea what personality number this washer may be. It would check something off my troubleshooting list if any one knows. Thanks in advance for any advice.
  21. Success! well, sort of. I've got one prototype made, ready for testing. Figure I'll throw it in the toolbag, try it out for a while, see if I have any notes. The action of the base pliers is so much better than the KP-2s, but I can't take credit for that piece of the puzzle; The "Masterbilt" or "Masterbuilt" pliers that I bought 2 of are allegedly mfg'd by Irwin, who I believe makes Vise-Grips. I originally ordered 2 Vise-Grips from Tooltron Industries, who claimed to offer a bulk discount on Vise-Grips, but after I placed my order they emailed saying they were actually out of stock, suggested substituting these. And they feel great in the hand. I'm not going to worry about nickel plating the heat affected zone yet; I'm pretty sure I'll grow out of these or want to make some changes before they rust, but nickel electroplating is still the long-term goal
  22. Manufacturer: Perlick Type of Appliance: Ice Maker Model Number: H80CIMW Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES I would appreciate it if you could provide a service manual for this make and model of ice maker. It will not stop producing ice. Thank you
  23. Thanks for the reply! I think I will sit this one out and hire someone to take a look.
  24. LG LF30S8210* Refrigerator Service Manual View File Pub MFL72005002 Rev 00 Submitter Captain Dunsel Submitted 05/11/2025 Category Appliance Repair Manual Pot Luck Supper
  25. LG LF29H8330* Refrigerator Service Manual m View File Pub MFL72005003 Rev 01 Submitter Captain Dunsel Submitted 05/11/2025 Category Appliance Repair Manual Pot Luck Supper
  26. GE WE04X25572 Front Load Washer User Interface Board Programming Part Install Instructions View File Pub WH00X5625 Rev 2 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  27. GE Dryer Personality Program Procedure WE04M10006, WE04M10012, WE04M10014, WE04X21166, WE04X27596, WE10X23597 and WE04X29099 Part Install Instructions View File Pub WE00X27074 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  28. GE CleanSpeak Dryer Control Board Personality Part Instructions WE04X20528, WE04X20527, WE4M544, WE04X20529, WE04X25174, WE04X25175 View File Pub 31-16703-2 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
