  2. Today
  3. Pull off the spray arm, take out screw and remove filter ring. Pull sump cover and clean it out. Check ball inside, clean it as well. If not clear to you, look up exploded view or service manual. This dishwasher does not have a drain pump. The main pump does the draining when the drain valve solenoid is activated.
  4. FIXED IT! Turns out Repair Clinic had 2 different timer motors listed as being compatible with this model originally, Originally I was able to find one of these two to replace the timer motor with. Finally was able to track down the other model number listed originally on RC and found a NOS one - this looked identical to the other timer motor, except for the model number stamped on it. This one works, and the dishwasher now drains out at the end of the cycle, as it did before, but now the motor and arms do not continue running while the DW goes into the drying mode!
  5. Vance R
    Lg dishwasher
  6. Yesterday
  7. Sorry, I realise now there is one available. I think I didnt set the proper search area focus before trying, after my search of another model number.
  8. Manufacturer: Fisher & Paykel Type of Appliance: Dishwasher Model Number: DD24DCTX6 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Fisher & Paykel DD24DCTX6 dishwasher service manual request Thank you
  9. Just to add some closure to this thread. The extended hose didn't work too good. I bought the updated sensor from Bosch. I separated the housing, drilled a hole in the housing so i can turn the screw with the housing back together. The new sensor alone (without touching the screw) allowed for a higher water level on all cycles. I'll still be experimenting with the screw to achieve a little more water so I can see it in the door seal gusset. Not looking for much water because I know it puts wear on parts- shocks, springs, motor, spider bracket, etc.
  10. Still nothing at LG web site for this refrigerator.
  11. Hi there! Anyone know what could be causing a dishwasher not to drain completely? I mean the pump is obviously working because it does drain about 85% of the water, but every time it finishes there is a small puddle of water. The filter is 100% clean and inside the dishwasher itself, all drain hoses are clean and clear, garbage disposal is also clean and clear. Took drain pump out and nothing was caught up inside of it or anything. Bad board? Bad drain pump? GE dishwasher model number: GSD3300K00BB Serial number: DL873297B
  12. Rich Armstrong
    Service Manuel Request
    Thank you Captain
  13. Last week
  14. Can I squeeze in here to insert mine, since Im looking for the same? Serial number 201MRRH2D902
  15. Thank you.
  16. Uses the same one as this model:
  17. Manufacturer: Thermador Type of Appliance: Hood Model Number: HMCN36FS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need the service manual and wiring diagram for Thermador Hood model HMCN36FS
  18. Manufacturer: Kenmore Type of Appliance: Washer Model Number: 110.2022251 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need the tech sheets for Kenmore washer 110.2022251. Thank you.
  19. Greetings, As the subject says: Light should come on when the water dispenser is used. Same light can be turned ON permanently with a LIGHT button on the panel. The light does not come on, either when pressing the water dispenser or the LIGHT button. The panel works fine, all lights come on, it is just the dispenser light. The dispenser in this fridge is super slim. Any idea how to approach this? Does anyone happen to have the service manual and is able to share? Thanks.
  20. Manufacturer: Lg Type of Appliance: Dishwasher Model Number: Ldfc2423v Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for service manual
  21. Uses the same one as this model:
  22. Manufacturer: Whirlpool Type of Appliance: Refrigerator Model Number: ET18GKXFW0 1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need the tech sheets (schematic, user manual, etc.) for this Whirlpool Refrigerator Model# ET18GKXFW0 1. The light comes on when the door is open, but no freezing, no cooling. Thanks for your help.
  23. Uploading tech sheet, service manual and waiting on approval:
  24. Manufacturer: Whirlpool Type of Appliance: Electric dryer Model Number: WED4720RW0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for the tech sheet for whirlpool electric dryer model # WED4720RW0. lightning strike has caused it to not work, the interface and all functions have seized. Believe it’s the board.
  25. You should be able to use this:
  26. Manufacturer: Fisher Paykel Type of Appliance: Dishwasher Model Number: DD24DCTX7 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Fisher Paykel DD24DCTX7 Dishwasher service manual request Thank you
  27. Uses the same one as this model:
  28. Manufacturer: GE Type of Appliance: Electric Dryer Model Number: DBLR333EG6WW Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Just looking for tech sheet thanks!
