  1. Yesterday
  2. I have an LG DLGX2502V dryer that just started tripping thermal fuse. I disassembled the exhaust duct work and cleaned it, though it was not very bad at all. I reassembled and ran it on air dry just to check exhaust flow, good exhaust at outside vent baffle. Still no heat, found the thermal limit fuse, was able to reset it and it ran, gas came on, and it seemed to be heating up fine. Shut it off, later on added wet clothes and ran it. Limit switch tripped again. Bad limit switch? What should I check. Thanks in advance.
  3. Captain Dunsel
    Service Manuel Request
    This should work:
  4. Manufacturer: Kenmore/LG Type of Appliance: Top load Washer Model Number: 79631512210 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Low water fill
  5. Try this one:
  6. Manufacturer: Huebsch Type of Appliance: Dryer Model Number: DR5102WE ZDE6HRYS177CW01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Huebsch DR5102WE ZDE6HRYS177CW01 dryer service manual request Thank you
  7. Kenmore Refrigerator model 10659212990. Water inlet valve 2206123. I bought a replacement water inlet valve 2206123. ...it's a triple solenoid model for a kenmore 10659212990. The incoming water supply goes to the brass nut - easy. But that's where I get confused. There's another solenoid (green) with a 1/4" port. I think this would go to the ice maker, and that's a 1/4" line that I can see running up the back of the fridge. So if I'm right, that knocks out 2 of the 5. So now I have 3 open ports on the 2206123 and they all appear to be 5/16". Coming from the fridge, there are 3 tubing lines bundled together before disappearing inside the fridge. 2 of them are 5/16" and the other is 1/4". How do I identify which tube goes into which port of the valve? (Unfortunately there are no documents on back of fridge or under front grate). It's an old fridge and no one seems to have any info on it. I'd appreciate it greatly if someone could help me out. Do I need to take the fridge apart to see where each of the 3 lines go? Hopefully not...thank you in advance...
  8. It sounds like a few things might be going on but it's hard to tell from this video. The drain pump sounds loud so I would investigate that for a blockage or restriction. Check for any play between the spin basket and the tub as that would indicate a bearing or basket support arm failure. Pull the back panel off and look for signs of leakage from the basket drive shaft. There should be some technical information tucked under the top somewhere. I would look for error codes to see what the control board thinks is wrong and why it's limiting spin speed.
  9. MrApplianceMatt
    Whirlpool WTW5000DW0 bearing repair?
    This would require a gear box replacement. The gear box is self contained and is not designed to be rebuilt. It includes the tub seal. Is there any lateral play between the tub and the basket? If so, then this would require replacing the basket as well. These machines were designed for economy, not longevity.
  10. Last week
  11. Thanks!
  12. I have a Whirlpool top load washer that has became rather loud on the spin cycle and I’m pretty sure it’s due to a bearing going out. Do they sell a bearing kit for this model?
  13. Captain Dunsel
    Request for Service Manual
  14. Manufacturer: Kenmore Type of Appliance: Electric Range Model Number: 790-94149310 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Please provide the service manual for Kenmore Electric Range model # 790-94149310
  15. Captain Dunsel
    Kitchenaid Refrigerator Tech manual
    Uses the same tech sheet as this model: This troubleshooting Guide comes up: May have some similarities to Parts of this manual:
  16. Manufacturer: Kitchenaid Type of Appliance: Refrigerator Model Number: KRFC704FPS01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Need a tech sheet or manual, please. Thanks
  17. Uses this mini manual.No exact service manual but you can work off these! This one: This one: And this:
  18. Manufacturer: GE Type of Appliance: Refrigerator Model Number: GSS25GSHBCSS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual for GSS25GSHBCSS
  19. Uses this manual: Uses this bundle:
  20. Thermador DWHD650WFP/01 Dishwasher Service Manual View File PUB 58300000211238 Submitter Son of Samurai Submitted 05/15/2025 Category Appliance Repair Manual Pot Luck Supper
  21. Version 1.0.0
    4 downloads
    PUB 58300000211238
  22. Manufacturer: Thermador Type of Appliance: Dishwasher Model Number: DWHD650WFP/01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need to request service manual/tech sheets for Thermador dishwasher model # DWHD650WFP/01
  23. This should work for you:
  24. Manufacturer: Kenmore Type of Appliance: dishwasher Model Number: 630.13953011 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): y I need a tech sheet for a 630.13953011 dishwasher please
  25. At first it was doing this intermittently and we thought it was a balancing issue. Now, it's every time. Although the machine does spin, it never spins fast and the clothes come out sopping wet. Doesn't matter how big the load is. I've tested it with one or two T-shirts and it still doesn't spin. Any ideas? Also, what is it that engages and makes that noise at 0:22 in the video?
  26. StaggsHomeAppliance
    Midea Refrigerator E6 Error Code
    @Captain Dunsel thank you!
