  2. Thanks for the reply! I think I will sit this one out and hire someone to take a look.
  3. Today
  4. LG LF30S8210* Refrigerator Service Manual View File Pub MFL72005002 Rev 00 Submitter Captain Dunsel Submitted 05/11/2025 Category Appliance Repair Manual Pot Luck Supper
  5. LG LF29H8330* Refrigerator Service Manual m View File Pub MFL72005003 Rev 01 Submitter Captain Dunsel Submitted 05/11/2025 Category Appliance Repair Manual Pot Luck Supper
  6. GE WE04X25572 Front Load Washer User Interface Board Programming Part Install Instructions View File Pub WH00X5625 Rev 2 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  7. GE Dryer Personality Program Procedure WE04M10006, WE04M10012, WE04M10014, WE04X21166, WE04X27596, WE10X23597 and WE04X29099 Part Install Instructions View File Pub WE00X27074 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  8. GE CleanSpeak Dryer Control Board Personality Part Instructions WE04X20528, WE04X20527, WE4M544, WE04X20529, WE04X25174, WE04X25175 View File Pub 31-16703-2 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  9. GE Dryer Personality Program Procedure WE22X35978 Part Install Instructions View File Pub 99-3000347 Rev 1 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  10. GE Washer Personality Program Procedure WH22X29348 Part Install Instructions View File Pub WH00X29498 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  11. GE Washer Personality Program Procedure WH22X35757 Install Instructions View File Pub 99-3000348 Rev 1 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  12. GE Washer Personality Program Procedure WH22X36477 Part Install Instructions View File Pub 99-3000362 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  13. GE Washer Personality Program Procedure WH22X36638 Board Part Install Instructions View File Pub 99-3000290 Rev 1 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  14. GE Washer Personality Program Procedure WH22X38441 Control Board Part Install Instructions View File Pub 99-3000334 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  15. GE Washer Personality Program Procedure WH22X37840 Control BoardPart Install Instructions View File Pub 99-3000289 Rev 2 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  16. GE Personality Program Procedure WE04X24754, WE04X25559 And WE04X23220 Control Boards Part Install Instructions View File Pub WE00X718 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  17. GE WB27X45467 To9 Oven Controls Personality Program Procedure Part Install Instructions View File Pub 99-2001165 Submitter Captain Dunsel Submitted 05/10/2025 Category Appliance Repair Manual Pot Luck Supper
  18. Mini update, really. After tooling up the lathe a little more and getting some more practice in, I've made a first set of jaws. I ended up making several of the male side first, getting quite a bit more efficient, but until today I didn't have a tailstock chuck for the center-drilling. They're not the work of a pro, and the dimensions may need to be tweaked, but I think they might be serviceable. Next up, unbox and set up the MIG welder I bought a while back
  19. Cool Thank you Captain!
  20. Yesterday
  21. Version 1.0.0
    0 downloads
  22. Captain Dunsel
    LG Refrig Service Manual
    You should be able to use this manual:
  23. Manufacturer: LG Type of Appliance: Refrigerator Model Number: LFXC24726S Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I need service manual and parts lists LFXC24726S thank you
  24. Version 1.0.0
    0 downloads
  25. Possibilities include but are not limited to: bad washer clutch, loose rotor nut, bad bearing in gearbox. If memory serves this washer "clutch" is more of a shifter that's cable driven and that cable could stretch preventing full shifting. It's function is to lock the agitator to the basket for spin and to disengage for agitate. It could also be coming from a failing drain pump but that's hard to determine from this video.
  26. If you're handy and tech oriented flip the machine and look for the tech sheet or it might be inside the console look at youtube to find out how then run diagnostic or calibrate it...
  27. Last week
  28. Kenmore Refrigerator Model Number - 10659212990 water inlet valve - 2206123 is one of several part numbers I've found water not flowing into ice maker : I have an old Kenmore from around 2000…The plastic chute that delivers the water to the ice maker keeps freezing over without ice being made. Water in door doesn’t work either (but I ONLY care about the ice part if that matters). I want to replace the water inlet valve but because its so old, there’s only one or two on the internet for ridiculous prices. It’s a triple solenoid type originally made by WP I think - I bought a similar triple solenoid model on amazon thinking I could make it work. I think it might have, but at the end one solenoid had wider metal connector tabs than the connector coming from the fridge so I couldn’t connect it. There must be an alternative solution besides buying bags of ice! Any help is greatly appreciated I'm attaching a pic showing the original on the left, and the new triple solenoid I bought that doesn't fit - in case anyone wants to see...
  29. You may have gookus(technical term for nasty, unwanted blockage) in the pressure switch hose, or the air dome in the tub. If that doesn't help, it's the control board. Disassembly will be something like this: I
