  2. Budget Appliance Repair
  3. Budget Appliance Repair
  4. Today
  5. Mr. Fox6000
  6. Yesterday
  7. Captain Dunsel
    Tech sheet needed
    Here you go:
  8. ecappliancecompany
    Tech sheet needed
  9. 98repair
    Miele G6625 SCU
    Any updates? Need it too
  10. I hope I'm following protocol here, I had a thread going about the defroster problem which is now I believe solved but on the way there I ran into a new problem. While I was waiting for the defrost heater sensor replacement to arrive, I pulled the cover off the back of the refrigerator. Anticipating that I might have to replace the control board if this part didn't do the job. At some point with the defrost heater still disconnected. I imagine I could plug the refrigerator in and get the fridge section to cool down saving my food from completely warming up. The minute I plugged the unit in there was some arcing on what I now know is the compressor control board. I waited until the replacement part. That is the defrost heater. Temperature sensor arrived, reinstalled it and then again plug the unit in and again there was arcing on this board. I removed the board. Looks to me like it's a rectifier full wave rectifier and the arcing. Is that the top of the board as you're looking at it from my troubleshooting experience? It's rare that there are two concurrent problems, but that appears to be the case. I can't think of anything that I did along the way to cause this bridge rectifier to fail. I'm actually thinking that I can procure the bridge rectifier and replace it on the board, but I'm open to suggestions. It looks like it's a pretty common board available on Amazon and other places. The illustrated replacement boards lack the second cap that appears on the upper right section of this board. The board number is itrp 04bx1.a. thanks for your help
  11. Akshesh
  12. Thanks, Captain!
  13. Forno FFSGS6291-36 Gas Range Installation Guide View File Pub 5015011 Submitter Captain Dunsel Submitted 06/27/2025 Category Appliance Repair Manual Pot Luck Supper
  14. Son of Samurai
    T18ID905LP/11
  15. Only found a installation guide with wiring diagram on page 29.Uploading and waiting on approval:
  16. Manufacturer: Thor Type of Appliance: Range Model Number: FFSGS6291-36 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yea Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need to request service manual for Forno range model FFSGS6291-36
  17. Last week
  18. service manual above
  19. Hi, it had a manufacture defect and i had to change the position of the evap thermistor. call their tech support, they are very helpful
  20. GE CleanSpeak Washer Control Board Personality Part Instructions WH12X21454,WH12X20504,WH12X20500,WH12X20503,WH12X20500,WH12X25674,WH12X25675 View File Pub WH00X5617 Submitter Captain Dunsel Submitted 06/27/2025 Category Appliance Repair Manual Pot Luck Supper
  21. Thermador VTR1400Q, VTR1000Q & VTR600R Roof or Wall Ventilator Installation Manual View File Includes wiring diagrams and installation instructions for these wall and roof mounted vents used as range hoods in combination with static range hoods and static vent tubing. Thermador ROOF OR WALL VENTILATOR MODELS: VTR1400Q VTR1000Q VTR600R Submitter Ananda Submitted 06/26/2025 Category Appliance Repair Manual Pot Luck Supper
  22. Captain Dunsel
  23. Manufacturer: Kenmore Type of Appliance: Dryer Model Number: 11068002010 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes
  24. Looks like 5.
  25. Manufacturer: Ge Type of Appliance: Washing machine Model Number: Gtwn7450d0ww Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I am looking for control board programming instructions for this model. Control part number wh12x20503. I did not see them in service manual. I did find instructions for other models but not this one.
  26. Manufacturer: Hotpoint Type of Appliance: Washer machine Model Number: Arxl129wsp Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hotpoint ariston Arxl129wsp washer documentation/service manual request Thank you
  27. Hi there, I have a Frigidaire FRFG1723AV03 that I am working on that is presenting some unique issues I haven't seen and was seeing if anyone has experienced this as well. Customer's complaint was unit was cooling intermittently. I had the customer plug in the unit to make sure it was running before arrival and it was cooling on arrival. I verified that the compressor was running and we were getting proper temperatures in both compartments. I went into diagnostics and verified unit compressor starts, the damper opens and closes, evap had a good frost pattern while running and that the evap fan was running. The last left was the control and the inverter board. I reset the unit and heard it attempt to start but it failed this time. I waited a while before attempting again and the unit did turn back on and begin cooling which was confirmed with frost pattern. My original diagnosis was a failure in the inverter board and wanted to see if anyone had an issue like this as well. I am reaching out to get the inverter replaced again but thought it couldn't hurt to see what the community thought. Thanks for any advice.
