Upcoming Events
- Today
clattin started following Samsung Refrigerator freezing food all of a sudden (Model RS25J500DSR/AA)
clattin posted a topic in DIY Appliance Repair Help
So our Samsung fridge started freezing food all of a sudden. I pulled it out and cleaned all the dust off the back and pulled the back cover off and cleaned the coils using a vacuum and compressed air. There was quite a lot of dust. But its still staying below freezing (29 F) with is set at the lowest setting (warmest). What do I do next to troubleshoot? Thanks! Chris -
JTST1 joined the community
Wackyracer joined the community
DaveRoc started following GFE28GMKGES Lights dim
The lights on my GE fridge have gone very dim. Everything else is working fine on the unit. The switch still turns them all the way off. Is this a bulb issue or indicating something bigger?
DaveRoc joined the community
Torp686 joined the community
C.Jackson joined the community
420.sean.69 joined the community
Jel joined the community
Ola G joined the community
leo5757 joined the community
Traxtar150 started following Ice maker leaking water in LG/Kenmore 795.79993.510 Refrigerator
Traxtar150 posted a topic in DIY Appliance Repair Help
The refrigerator is mentioned in the service manual linked here: I cannot afford the tech account fee to download this document... Can anyone advise me on what to replace when the ice maker creates ice and keeps it frozen, but also leaks water behind the ice maker assembly? I have detached the entire ice maker assembly from the door and found ice buildup behind it, covering the wiring harness and motor. This water also accumulates behind/under the plastic covers surrounding the ice maker. I cannot tell if there is water leaking inside the door itself... It doesn't look like it. I don't see any obvious cracks on water lines. - Yesterday
Thermador Range gas burner won't light
Canadaovenfixer replied to swedespeed's topic in DIY Appliance Repair Help
Working on a Thermadore Professional PRG304US gas range/oven. It's an older model. There are 2 simmer burners +2 standard burners. The front simmer burner was on and made a very loud "popping," sound before shutting down completely. Following the "pop," both the front and rear XLO/simmer burns quit functioning (no power light on, no spark, no gas). The other 2 burners and the oven are functioning normally. Have replaced both potentiometers with new replacement parts as well as the ignition device. Both burners are still not functioning. No electrical or gas. What would cause this? Faulty gas value? Thanks in advance for your input. -
After hooking up washer, started a load but the machine stopped after wash cycle. Water didn't drain. Drained it manually, checked level, opened it up to clean filters and hoses. Noticed the tub is cocked back. Didn't think it was right by continued checking for clogged pipes and such. So have same problem and can't find anything that shows me how the tub is suppose to be, and how to fix it if it's not sitting right
Appliantology Live Dojo, Saturday, 4/27/2024 @10 AM ET
Nicholsseand commented on Son of Samurai's event in Tech Training
R600a starter kit
goldnkoi commented on Koi Guy's blog entry in Koi Guy's Amazing Compendium of Timeless Appliantological Wisdom
I was wondering where I could find a charging assembly like that nu-calgon one. Thanks for sharing this! oh, how does that vacuum pump work for you? It’s much cheaper cost wise than a cps. -
goldnkoi commented on Son of Samurai's event in Tech Training
until
Ugh I’m sorry I missed it. Have the stomach flu bad.. 🤮 looking forward to the recording. I even did my homework on it.. - Last week
This happens to have happened when I installed a new washer right next to it, so maybe it is from physical damage or something else. I don't remember hitting the unit at all. When the start button is pressed, there is a buzzing sound but there is no turning of the drum. If I move the dial to other settings (I included a screen shot of the dials below), such as cottons, there is no buzzing at all when I press the start button. Also, on the time dry setting, it will not buzz at 80 minutes but will when dialed down to 60. If there is buzzing, I assume there is no issue with the door switch or power to it. I checked the vent and it seems to be clear. Any suggestions anyone might have as to the issue I would greatly appreciate the insight. I am going to be gone for the evening but if there are any follow up questions, I am happy to answer them when I can. Thanks for the help!
Electrolux Frigidaire Refrigerator Twist Tray IM Thermistor Conversion Chart: Temperature and Resistance View File Pub RFTT2434 Submitter Captain Dunsel Submitted 04/26/2024 Category Appliance Repair Manual Pot Luck Supper
ASTI 2021 Hisense Refrigeration Training Notes
mehoss commented on Son of Samurai's file in Appliance Repair Manual Pot Luck Supper
790.8883110 Kenmore microwave tech sheet needed
Appliancescienceindy replied to Appliancescienceindy's topic in Appliance Service Manual Requests Forum
Thank you for the help. -
Kenmore refrigerator tech sheet
Dan the Appliance Man replied to Dan the Appliance Man's topic in Appliance Service Manual Requests Forum
Thank you!!! -
Captain Dunsel replied to Dan the Appliance Man's topic in Appliance Service Manual Requests Forum
Service Manual request for Wpl Elec R/O - MN WEE745H0FS0
alphaapp replied to alphaapp's topic in Appliance Service Manual Requests Forum
Thanks very much! -
Dan the Appliance Man posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Kenmore Type of Appliance: Refrigerator Model Number: 10658519801 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Is there a tech sheet around for this? Thanks, Dan -
Tech sheet request for Kenmore washer 796.41362.910
Son of Samurai replied to tonyf7's topic in Appliance Service Manual Requests Forum
Thanks, Vance! Approved those. -
LG Washer Replacing Tub Assembly for Loose Balance Weight Bolts Service Bulletin View File PUB DFZ202100127-01 Applicable for models: (WM3400CW / F3U8CNU3W); (WM3460CV / F3L2CNU9T); (WM3460CW / F3L2CNU3W); (WM3500CW / F3L2CNU4W); (WM3600HVA / F3P2CYUAT); (WM3600HWA / F3P2CYUAW); (WM3700HWA / F3L2CYU5W); (WM3700HVA / F3L2CYU5T); (WM3900HWA / F3L2CYU2W); (WM3900HBA / F3L2CYU2W); (WM4000HBA / F3P2CYUBE); (WM4000HWA / F3P2CYUBW); Submitter Vance R Submitted 04/26/2024 Category Appliance Repair Manual Pot Luck Supper
LG 796.41362.910 Washer Service Manual View File MODEL : 4136# Submitter Vance R Submitted 04/26/2024 Category Appliance Repair Manual Pot Luck Supper
Vance R replied to tonyf7's topic in Appliance Service Manual Requests Forum
This service bulletin comes up: -
Uploaded service manual: -
Version 1.0.0
4 downloads
PUB DFZ202100127-01 Applicable for models: (WM3400CW / F3U8CNU3W); (WM3460CV / F3L2CNU9T); (WM3460CW / F3L2CNU3W); (WM3500CW / F3L2CNU4W); (WM3600HVA / F3P2CYUAT); (WM3600HWA / F3P2CYUAW); (WM3700HWA / F3L2CYU5W); (WM3700HVA / F3L2CYU5T); (WM3900HWA / F3L2CYU2W); (WM3900HBA / F3L2CYU2W); (WM4000HBA / F3P2CYUBE); (WM4000HWA / F3P2CYUBW); -
Vance R posted a file in Appliance Repair Manual Pot Luck Supper
SHU4322UC/U12 Service Manual
Son of Samurai replied to Ken King's topic in Appliance Service Manual Requests Forum
Uses this manual:
Blog Entries
5 comments
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog1 comment
6 comments
12 comments
Topics
until
