Patrick.j Posted April 20, 2022 Share Thanks guys! Got an e84 tomorrow! Link to comment Share on other sites More sharing options...
tfre Posted March 6, 2023 Share This is a terrible service bulletin. It only addresses an E84 "Communication Error "Cooktop to Oven" (E-84)".The picture showing the relevant wire harness for the sub pcb is wrong. I was getting an E84 within 10-15 seconds of plugging the range in. Went with a new induction board assy. These induction boards have a tube fuse on both induction boards. One was open. Replaced the fuse, put it all back together, plug in and POP. Line fuse blew again. Had to take completely apart again and replace the whole assembly. Worked after that though. PITA, should have bid this higher.... 1 Link to comment Share on other sites More sharing options...
