Click here to take the quiz.
Blown Motor Control Board in a Maytag Neptune MAH5500BWW Washer
If the control panel display is dead on a Maytag Neptune MAH5500BWW, get a visual check on the motor control board down below before you order and replace the machine control board or you could be in for an unpleasant surprise!
You can find the replacement machine control board and motor control boards with a one year return policy on this page ==> http://www.repairclinic.com/Maytag-Washing-Machine-Model-MAH5500BWW-ID-563804-Circuit-Board-Timer-Parts
Be sure to have your serial number to order the correct board.
Washer Repair
· 69 images
  • 69 images
  • 17 image comments
  • Taken with Apple iPhone 4S
  • Focal Length 4.3 mm
  • f Aperture f/2.4
  • ISO Speed 64
