Frigidaire built Front Load Washer Dispenser Magnet
Sign in to follow this
Washer Repair
  • 68 images
  • 13 image comments
If the control board is replaced, this safety switch is no longer used. It wasn't as big of a deal as FA thought it would be. If you can't fine the magent. wire nut the two wires together. You'll see them. Two black wires leading over to the dispensor.
Share this comment
Link to comment
