  1. Yesterday
  2. Problem just started today. Noticed a grinding noise coming from the drum while spinning by hand or during spin cycle. Sounds like bad bearings / lack of lubrication to me but ultimately unsure the root cause and whether it’s cost effective to repair. IMG_1572.mov
  3. On the same day, the freezer light died and two of the interior lights (top of interior) are dimmer than usual with a slight blue-ish color. The rocker switch in the freezer is moving. I understand these are wired in series so I probably don’t need to replace all of them. Any suggestions where to buy? I found one place that has all the replacement lights, 12 in total with three hardwired together. This doesn’t seem right.
  4. Manufacturer: Cove Type of Appliance: Dishwasher Model Number: DW2450 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes The model number shows up on Google but not on repair clinic. I’m looking for a service manual with the diagnostic menu, codes and a schematic.
  5. I'm getting error codes but, unless I'm blind, I'm not seeing the key to read the binary on the tech sheet. Below is what the tech sheet says regarding reading the error codes "Look for LED group 5 and group 6, it shows the fault and error codes mentioned in binary format. Fore detail on how to read binary format, see Tech Manual. Press Key 3 to show next fault and error code."
  6. It is a zip file with about 27 documents in there.
  7. Not able to open this when downloaded. Trying to open with apps that arent related to docs apps
  8. Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHU4322UC/12 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes SHU4322UC/U12 Service Manual
  9. I have not been able to find anything on this one. Anyone else?
  10. I don’t have anything either.
  11. I've got nothing on this one, so we might be out of luck unless either @Captain Dunsel or @Vance R has something
  12. Son of Samurai
    790.8883110 Kenmore microwave tech sheet needed
    Domo, Captain!
  13. Son of Samurai
    Tech Info.
    Thanks, Cap!
  14. GE GUD27GSPM1DG Laundry Center Mini Manual. View File Pub 31-3000108 Submitter Captain Dunsel Submitted 04/25/2024 Category Appliance Repair Manual Pot Luck Supper
  15. Kenmore Frigidaire 790.48883110 Microwave Wiring Diagram View File Pub Wiring Diagram 316902474 Pub Parts List 5995599304 Models: 790.48883110 790.48893110 Submitter Captain Dunsel Submitted 04/25/2024 Category Appliance Repair Manual Pot Luck Supper
  16. Frigidaire FGMC3066UFA Microwave Oven Combo Parts List View File Pub Parts List 5995711644 Models: FGMC3066UDA FGMC3066UFA Submitter Captain Dunsel Submitted 04/24/2024 Category Appliance Repair Manual Pot Luck Supper
  17. Hey there. Have a GE Spacemaker Washer that won't engage to spin or agitate. Blocked motor error code comes up. There is no blocked motor. GUD27ESSJIWW Following has occurred and looking for next steps guidance. GE Tech came out months ago to diagnose. Said most likely bad motor. Only put it into diagnostic mode to see error code. Never did any electric tests on board or parts. Ordered whole new tub assembly with new transmission, motor, speed sensor, tub. Tub assembly finally came which was back ordered. Tech installed tub assembly. DID NOT solve problem. What is occurring is if tub fills after it fills it won't agitate. You can put it into spin after reseting and it will drain the water but then won't spin. If you go into diagnostic mode and engage the spin test, it will start the drain pump and if you watch the fork assembly with the gears/actuator you see them move into place to start locking tub to motor/pulley. After the black/white gears lock into place, a few seconds later blocked motor error code comes up. Drain pump stops also since error occurs. Tech has now ordered new computer control board after calling tech support (he never checked board the first time on diagnostic trip) and tub assembly motor might not have been issue at all (which is annoying but luckily didn't have to pay since it didn't solve problem). He swears he checked the board the first time and I said he absolutely did not. I watched him the whole time. I don't have the confidence in this repair technician from GE anymore since they didn't do their due diligence the first time and check the board. Any suggestions on what else this could be to cause this? I'm now 3 months without a washer. I'm curious if I should try the unplug and do the lift 6x thing I just saw today on a site. Thanks for any guidance or help.
  18. BaineB254
    Whirlpool Refrigerator Leaking Water Help!!
    Probably a defrost issue or just clogged drain line. Remove back panel and check for continuity on defrost heater. If it has continuity, but evaporator is solid ice, replace defrost thermostat. (sometimes it comes built in as part of a harness to the evaporator fan) and defrost the drain line using a steamer. You should hear the water gurgling down after a minute. If it doesn’t drain, check the drain tube for physical restrictions. GL🙂
  19. BaineB254
    LG DLEX9500K Dryer constantly throwing d80
    Just a guess, check the blower wheel area and lint duct/outlet for restrictions too, and reset the board by unplugging. Check the wiring and harnesses too. If the thermistor has been replaced that’s all I can think of! GL🙂
  20. Water pressure was really high! Filter only 4mos old. Inlet valve showed resistance but no continuity. Power to inlet valve confused me. It showed 2v with door open, 3v with door closed, and dropped to 0v when I press the water dispense paddle (while pressing door switch). But I could hear a click from the valve area like it was getting power! 🤔 Recommended the valve first. wondering if anybody else has other ideas or experience with this model?
  21. BaineB254
    GE GTW335ASN2WW won’t finish cycle
    Update! After removing the metal piece from the outer tub and replacing the drain pump it starts working 🥳
  22. Version 1.0.0
    0 downloads
    Pub 31-3000108
  23. Captain Dunsel
    Tech Info.
    Uploading mini manual and waiting on approval:
  24. Uses the same tech sheet as this model:
