I usually dont work on thermador products, but i have one that has came across my path and want to give it a shot . (im here in the diy section because my free access is through the mst training)
The left two burners on this particular unit are iffy as to when and how they work, from just what one tech has told me they have a feature called "extra low" which is apparantly , according to him, controlled by a module to those two eyes so that the gas and spark can be turned off and on to simmer food more evenly without burning it and that is the suspect part.
Im wondering if anyone has any info on this issue with a thermador gas cooktop or range. I am deciding if i want to take this on.
The only "extra low" I've ever seen has been a small adjustment screw either down the center of the knob shaft or next to it that allows setting the flame size when the control is set for minimum. No idea about anything do do with a spark, except that some cooktops have auto-relighting if he flame goes out.
Thermador may have something different. I hardly ever see thermador and TBH I didn't even know they were still in business.
They do Terry, almost all Thermador gas surface burners the left side burners have the XLO feature.  They run a special spark module, potentiometers instead of spark switches and electronic solenoid gas shut-off valves to left side burners - it cycles the burners ON/OFF for the XLO feature.
  • Thanks 1
You should be able to post in the other forum and then get the manual I believe. Especially if you're going through the training. I think you just have to go through one of the steps in training. @Samurai Appliance Repair Man @Son of Samurai could you explain or point in right direction.
@WestTn- you're posting as a Grasshopper-- that's a free DIY account. See this page for info on how to get your free 6-month MST Student account, which is one of the professional tech accounts here at Appliantology: https://mastersamuraitech.com/appliantology-membership/
Here's an excerpt from that page:
Quote
Our Free Appliantology Membership Packages
  1. Every new Master Samurai Tech student receives a free 6-month Professional Appliantologist membership, so they can access this valuable resource from day one of their training.
How to register: The sign-up form is in the Appliantology 101 course, which all students can access.* Go through Units 1, 2, and 3, then you’ll be good to go. (* You’ll find Appliantology 101 in your list of courses on the Members Area page, which is the page you land on when you log in. Or, if you’re already logged in, click “My Courses” in the campus menu.)
  1. Every Master Samurai Tech student who receives their certification in our Core Appliance Repair Training course receives a free 1-year membership! And that’s just to start!
How to register: For details on our certification program, including how to qualify and what you receive, check out our MST certification page. Once you’re certified, just fill out this short form, we’ll review it and set up your Appliantology account mo’scratchie (that’s Samurai-speak for “quickly”).
 It's a great deal. You should take it!
