Kitchenaid Dishwasher not filling with water
fatherfigure4life
I have a Kitchenaid KDFE 104DWHO Dishwasher that started not cleaning dishes well. It did not seem to have any water, so I dumped a pitcher of water into the unit and it started working again. Quick google suggested a bad inlet/fill valve. Replaced valve without any change. I then decided to be more scientific. Tested the voltage at the fill solenoid and got about 16VAC without load and 0.02 with solenoid connected (solenoid functions when bench tested with 120VAC). I then replaced the Control board without any change. I have opened the wiring loom and inspected all the wires finding nothing of concern. Tested: fill valve wiring, float switch and wiring, door latch switch and wiring, and replaced the turbidity sensor.
Dishwash will function if I manually open the door and pour in water. Seems like the machine believes that it has water when it does not, as the pump and heater still function while  the machine has no water.
Help!!! I am sure that the solution is obvious, but it baffles me.
  • Replies 5
  • Nathaniel Peterson
  • fatherfigure4life
Make sure if it has a float switch on the bottom of the tub on right side that it's not stuck in the up position.
Also pull off the kick plate and make sure there no water under the foam disc / overflow switch (different than float switch)
fatherfigure4life
Thank you for your response. I am not sure if this model is equipped with an overflow switch, or at least I am not able to find it. Any suggestion on locating it?
If it does it'll be on a plastic tray that goes across the front of the dishwasher right behind the kick plate. If it's there you can't miss it.
fatherfigure4life
Thank you for the clarification. No, this unit is not equipped with an overflow tray. Any other thoughts on the cause?  The only other thing I can think of would be some kind of poor connection at the turbidity sensor (I have not continuity-tested that harness yet).
