Model 417.61712510 Kenmore washer/dryer combo won't start?
redline808
I have a Kenmore washer dryer combo that was in storage for a while. worked when stored. dryer works fine. the washer will not start in any position. I can get it to fill with water in the rinse spin mode but it will not drain, it just fills up with water and stops. If I play around enough with the different modes, I can get it to drain but once its empty, the pump just surges and keeps trying to drain an empty tub. any ideas? thanks.
  • Replies 6
  • redline808
    5
  • dfphoto
  • vee8power
redline808
Lid switch seems to be working fine
anyone?
Have you put it in service mode? Are there any error codes?
How do you know this?
Because I can get the washer to do some functions. I took the front panel off and watch it actuate when the wash is started.
I would check the wires in the back of the tub, had a similar unit with frayed wires.
Okay, I will. TY
