Maytag Laundry Center Model # LSE1000
Go to solution Solved by RegUS_PatOff,
The subject model is a "computer touch control" model.  There are 3 cycles for drying.  However, the dryer only comes on when the "perm press" button is pressed.  I suspect that the touch pad is bad.  Or could it be the control assembly?  Is there any way to get a service manual for this machine?  Thank you.  Regards, John
  • Replies 4
  • Sonic
  • RegUS_PatOff
  • John E. Hoagland
Could be a the touchpad, or a problem with the motor. Some clever poking with your meter will tell the story. The service manual for this unit is one of the best out there. Here it be.
  • 5 years later...
I'm tackling this beast as well and could really use a copy of that manual. I do have a manual that states at the bottom that it covers 1994-1997 models.  If that is the right one I'm not sure witch model in the manual covers the LSE1000.
To the rescue again! Thanks
