Sears Mod 25373185300 Window AC, 220v
couchgrouch
couchgrouch
            Compressor cycles on (about 2 seconds) and off in "Cool" mode; takes about 10 seconds before compressor cycles again, with no cool air.
 We pulled the AC from the case, then I used 'Foaminator', or some good stuff like it to clean cooling fins- had to clean them twice, they were so filthy.  Unit is in a rental trailer, so you know how well the tenants kept the filter cleaned.
Do we need a new AC?
  • Replies 4
If the start capacitor is good, yes......have the capacitor tested or look to see if the end is bubbled up and not smooth and straight across...mark your wires to the capacitor and carefully remove the wires, be sure the a/c is unplugged and you dis-charge the capacitor with an insulated screw driver first.  If the top of the capacitor is really bulged out you are going to have to be really really careful removing the wires without it exploding in your hands...if it is bad match up the size and shape and the mfd ratings posted on the side...
couchgrouch
Guess the condenser is on top of the compressor???  I removed the rubber cover- condenser looks normal; no bulging, bubbles, or discoloring. Condenser is about 1 inch diameter, round, and looks like a car's turn-signal flasher?
Lastly, to discharge- all I need to do is touch both condenser contacts with an insulated screwdriver, after disconnecting the 2 condenser wires, correct???
CAPACITOR.....not the overload....the condensor is the outside coil......
