Any one have a service manual for a EI26SS55GSO Electrolux SXS fridge ? I need to know how to get into diagnostic mode. Freezer temp going up and down and customer in panic mode over soft ice cream.
  • RegUS_PatOff
  • appl.tech.29501
To get into diagnostics......
Press and hold the "freezer" temp. Up / down keys at same time for 5 seconds (if this has wave touch controls you must illuminate the display first).
All LEDs will light up...press the FF "up" key to clear the display...pressing the FF "up" key again will begin the first test
Display will show current test # in progress 1,2,3 etc. Pressing the ON/OFF key will turn off and on the particular load in the test...fan motor ,heater etc.
No key press in 5 min. Will exit the test mode
Order of tests.....
1) compressor
2) defrost htr.
3) FF lighting
8) water valve (dispenser only)
9) freezer lighting
10) auger motor
11) cube/crush solinoid
12) VCC condensor fan
15) Evaporator fan (toggle for "low" and "high" speeds
22) Damper test
23) FF door (OP=open / CL=closed)
24 Freezer door (OP=open /CL = closed)
26) Defrost limit switch (" ")
28) dispenser paddle test (press ON/OFF pad and press paddle with door. closed to test.
36) Ice door test (solinoid should activate when ON/OFF pressed freezer door should show ice door closed.
29) FF thermistor (press ON/OFF, "0"=good. ER = open/shorted
30)Freezer thermistor (" ")
33) Ambient Thermistor (" ")
34) Formware Version
38) VCC models only....compressor test
To exit diagnostics.....press and hold the "FF UP" key for 5 seconds...control will beep and test mode deactivates.
Thank you so very much, the info will be very helpful:rah:
