Click here to take the quiz.
Whirlpool GU2300XTVQ Dishwasher, will not wash (pump not running) drains OK
Hi there,
Need a service manual to perform diagnostics on this machine. It fills, will not wash, no noise from pump. Cancel/drain works fine.
Thanks--
-Matt
EDIT. OK it runs....*a little* sometime. Just tried it on "rinse only" cycle, pump ran about 2 seconds then shut off.......
Edited by mattmag
  • mattmag
  • RegUS_PatOff
Tech Sheet - W10142800.pdf
link Pm'd
Thanks much--- I'll run it through the diagnostics and see what happens. I'm a little concerned with the intermittent nature of this thing. I was hoping the pump was either a go or no-go, but I have found that it will run for a second or two at times, and others it won't start at all. I believe that would rule out a start capcitor?
