Help troubleshooting treadmill with GE 1/2 hp motor
Ok, I know the first answer to this is : take it to a junkyard or scrap the metal. But I am determined to make this work regardless if it makes sense or not at this point. Now that that's out of the way...This is an old treadmill from like 1988, and it worked until about 5 seconds before I loaded it up and brought it home. Didn't really see a spark or flash or anything, it just stopped like a normal stop if you pushed the stop button. I picked up a new relay because it was just a few bucks and they had it at my local elect.supply store. I swapped it in with no results. I've checked pretty much every wire and switch that I could with an ohm meter. But I don't understand what the relay does inside or why it's there. Or how the stop button works (whether pushing it is supposed to open or close the switch, but right now the way it is wired it opens the switch when you push it. The master power is closed in the on position and open in the off position. The "start" bump switch is closed when you push it and open when you let go. The "reset" breaker doesn't seem to do anything, but it meters closed and I bypassed it once an tried that with no result. I read on another site to rotate the motor manually and see if it produces voltage, and it does. So I don't know where to start next. Any ideas would be greatly appreciated. Here are some pics and sadly hand drawn wiring detail....I can post the drawings with more detail, but with the 500K limit this is all I can post for now.
post-75560-0-20929100-1349994370_thumb.j
post-75560-0-11922500-1349994371_thumb.j
post-75560-0-17430400-1349994372_thumb.j
post-75560-0-05240700-1349994373_thumb.j
post-75560-0-09882900-1349994374_thumb.j
post-75560-0-15581100-1349994375_thumb.j
post-75560-0-11145700-1349994376_thumb.j
post-75560-0-10372900-1349994377_thumb.j
  • Replies 13
  • scconsulting
    8
  • RegUS_PatOff
    6
Posted Images
need better images of the (2) wiring diagrams
upload them somewhere ( http://imageshack.us )
free... no need to register (free), unless you want to keep track of your uploads
then post the links here
Ok, here is the first one
I split the panel wiring into two, helped a little
post-75560-0-52229700-1349997571_thumb.j
post-75560-0-59840500-1349997661_thumb.j
post-75560-0-76650200-1349997663_thumb.j
If you still need them better I will try the imageshack deal, just let me know. Thanks a bunch for the quick response. Whether we get this or not, you are awesome for trying, I really appreciate it.
I can't understand the wiring diagram symbols..
Need an actual picture of the bottom of the Relay (and part number)
click on picture
With the Main Power Switch ON
and the Start Switch momentarily pushed ON
The Relay should energize, and stay energized unless the Stop Switch is pushed
When the Relay is energized, there should be 120v AC at the Motor:
Red to White
It's getting late, I will try tomorrow to see if the relay energizes when I close the start switch. And just to clarify when the stop button is pushed it is supposed to open? and this is what you are saying will de-energize the relay? thanks again, I will check back tomorrow.
... when the stop button is pushed it is supposed to open?
... will de-energize the relay?
1) yes
2) yes
Well I got it fixed....and I feel like a total idiot. I knew in my heart everything was metering out correctly...just didn't trust myself. Turns out the main power cable running from the motor up to the panel had a big chunk out of it. In some speed positions I guess it was chaffing on the main drive pulley. Looked like a rat chewed through half the cable...I never saw it because it was in a tiny dark hard to access gap. So I cut it, stripped the 3 wires and reconnected them with the twister type caps...taped it up and boom...fired right up first time I hit the switch. I want to thank you again for the help...Even though it was a simple problem, I would have just given up before I found it if I hadn't found your site. It's totally awesome, and I'm glad I paid for a membership. Maybe we can dig into my toaster in the next month or so! LOL! Can't thank you enough... :dazzler::thumbsup::thanks::rocker: :rocker: :rocker::thanks::thumbsup::dazzler::woohoo:
:whistling:
