    • 15 March 2025 02:00 PM Until 03:00 PM
      5
      When: Saturday, March 15 @10:00 AM Eastern Time.
back in Nov this customer first had someone out for a ff frzing issue, i determined it to be a damper, replaced it cheked  it as to its opening and closing when i put it in.
went back today and the new one is stuck open, i turned the dial the damper dos not move, no audible motor at all?
i snapped a pic of fridge side control, thinking it may missed wired.
post-82511-0-38570700-1392931647_thumb.j
  • Replies 5
  • brm
    4
The service manual won't be of much use to you on this one.  But I would refer you to Brother Durham's fine Frigidaire Refrigerator Survival Kit:  http://appliantology.org/blog/15/entry-748-frigidaire-refrigerator-survival-kit/
If it's been working since November, then it's highly unlikely that you missed a wire. More likely on this model is that one of the other associated controls have gone bad. Interestingly, on the FRS26 models, Frigidaire has you simply gut all the controls with this kit Part number: AP5176342
Unfortunately, that kit does not apply to the FRS23 models. Instead, you will need to replace the fresh food cold control Part number: AP2116225
and the ADC board Part number: AP4909015
thank you GM
the customer said the first company out, had changed the ff control and had been there 5 times and the frzing issue had never been resolved.
when i got there the damper was stuck open & motor did not run. i changed the damper & today 4 days later i find the same problem, the new damper is stuck open & motor dos not run. so i thought (guess) maybe he missed wired it.
but gust thinking out loud, the new ADC & wire harness it should do it, cuss as i remember the damper is rewired  with that wire harness, having only one side of the damper wired, the old wire harness is whats on there now.
thank you agin
the Frigidaire Refrigerator Survival Kit: that is amazing thank you
from Service Manual # 5995352423 i found on pg.19 that  the FF control is missed wired.
which leads to the question do you think the damper i just put in, shud it be replaced again with the parts you forementioned ???
At this point, you don't know what you're dealing with.  And I still wonder why they waited so long to call you back if that were really the problem.  And then it gets into the who did what.  But, since you were the last one to touch it, you own it.
You could try correcting the wiring and see if that fixes it.  But you have to ax yourself, "Self, what's my time worth?  More importantly, what's the customer's opinion of me worth?"
FWIW, if it were me, I would gut the beast, making sure I fixed it in the very next trip and not get a callback in another couple of months.
point taken gut it ,it is
thank you, You have the best site on the internet.
