MTC(SS) Posted April 1, 2014 Posted April 1, 2014 I have searched the posted manuals and there is one that is close, the LG WM2487H*M. I've downloaded that one but am unsure if it is complete for WM2496HSM. Water's not draining. I did not run diagnostics, I went for pump before I downloaded the 2487. The controller is a different part number between the two units. Thank you for you help.Jeff
LI-NY Tech Posted April 1, 2014 Posted April 1, 2014 http://appliantology.org/files/file/1646-lg-washer-service-manual-wm2496hm/
