New Appliance Service Manual added: 3E Error Code Diagnosis Guide for Samsung FL Washers
File Name: 3E Error Code Diagnosis Guide for Samsung FL Washers
File Submitter: Samurai Appliance Repair Man
File Submitted: 16 Nov 2014
File Category: Appliance Repair Manual Pot Luck Supper
Subject: 3E Error Diagnosis Guide
Possible Causes
• Main PCB Defect
• Hall Sensor Defect
• Motor Defect
• Wire Harness Defect
Evernote enex ZIP
Click here to download this file
  • Replies 0
