New Appliance Service Manual added: GE Advantium 120 Speedcooking Oven Service Manual
  • 3 years later...
  • Replies 1
  • AtomicSteve
Having trouble with a model scb1000kww01.  Initially there was no display.  It still functioned fine if you know what to push.  I found that the digitron was suspect and replaced it.  I then have fixed the display issue with a strange flickering still showing on time digits as if the segments are lighting on their own in a wave fashion from left to right.  I went through all the solder connections to see if any cold joints or issues.  I touched up a few suspect points on power board but the rest looked ok.  All functions were perfect other than the flickering display.  My parts supplier let me exchange to see if I had a bad digitron but the new replacement has the same problem.
I left it as a flickering functional unit to research more but customer called back to say totally dead.  I went back and it was dead.  Unplugged and checked fuses and tco's.  All ok...then plugged in and all ok again with the flickering display still happening.
I left again but just received a note that it is dead yet again.
Anyone have any of these same issues?  I will go back but hopefully with new knowledge.  I plan on using this manual to go section after section to retest and see what I missed.  Argh!
